Theory is no problem. Theory is easy... its practice that I am interested in...
care of wikipaedia:
kW = (Nm * rpm) / 9549 (k constant)
I just hadn't thought that ramp rate / engine load would make such a large difference. Then again, I geuss the stock rb20 turbo runs out of huff pretty quickly (like around 3.5k rpm) when compared to a large aftermarket turbo.
So power would be the same, but torque up by ~1.3 x (3rd gear ratio). cool
keeping with the idea is the original question (3rd or 4th gear), would there be any difference in transmission loss b/n the gears? or is 20% squishy enough not to care?
  • Replies 44
Posted Images
lol at the stock rb20t turbo running out of puff at 3.5k, they are small but they aren't that bad.
Mine used to get going at 3.5k @1bar and would hold 1bar until a shade over 7000rpm where I would shift up.
Poor boost controllers would have boost dropping off at high rpm, fitting up a decent controller picked up 10rwkw and gave it the feeling that it keeps pulling and pulling until a shade over 7000rpm.
When i was happy to blow my rb20 turbo, i ran an old elc boost controller which made 1bar by 3000rpm and 18psi soon after, it would drop off to 1bar by 6500-7000rpm (didnt used to watch boost controller that much at those rpms lol) and hold 1bar well into the 7000rpm's!
The stock rb20 turbo isn't too bad if you have a good boost controller at holding decent boost, but it wont hold too much obviously due to the wastegate spring and of course its size!
In regards to the dyno i thought it was well known 4th gear gives the best readings, 3rd (if you ave speed limits etc) shouldn't be TOO far off, closer obviously if ur car is closer to stock also hehehe
Well one would think that in lower gears the less load on the motor will mean potentially less power with a turbocharged car.
But how come when I gun it in 1st gear to redline I'll still get the same peak AFM voltage as I would if I had kept going through the gears? Ie ~4800mV on a Z32... its interesting cos first gear only last a split second where as 3rd might last about 5 seconds which gives plenty of time for the turbo to spin hard.
Its been the same case in both cars I've had.
Thats quite interesting... I don't hit my peak voltage until third gear, granted first and second are wheelspin.
You shouldn’t confuse what happens on the road (in the 2nd or 3rd compared to 4th) with what happens on the dyno. On the road the car accelerates so fast (or wheelspins so much) that it doesn’t have time to build up the load to produce the exhaust to spin up the turbine. This is not the case on the dyno, where the operator can vary the load (on the rollers) to slow up the rpm increase and give the engine time to build up the load to produce the exhaust to spin up the turbine.
So when talking gear comparisons on dynos you can ignore load as a factor of difference.
:D cheers :P
4th gear should produce a handfull more bhp at the wheels. 3rd gear is a helical gear set meshed between gears on the mainshaft and layshaft. the helical gears will create side loads and extra friction and drievtrain losses.
4th "gear" on the other hand simply connectes straight through the mainshafts in the gearbox - no gears involved, no side loading, no meshing frictions. all of this equals less drivetrain losses.
but it will only be a few kw.
Ah but what I mean in my experience that despite the lack of 'load' in 1st or 2nd gear (wheelspin in both gears), I still get pretty much the same AFM readings, both on my old car with a stock turbo and my current car with a bigger one.
Hmmmm...
So you really get exactly the same load, must be an sr thing? :D
I had a fiddle today, dropped boost right back to 7psi, first and second gear saw less load, third and fourth saw the same, I am unable to really wind fourth out as thats past the speed limit but comparing similiar rpm saw almost the same load... My third is little due to the lack of rpm 5500rpm max until valve springs are sorted. which fingers crossed is next week. :P
Yeah must be an SR thing. Power in any gear. :P Or.. I again need a bigger turbo :D
I guess by dropping the boost back and getting the same load, that means that your boost is tapering up top? So just a phatter midrage with larger boost... Still cool I say. ;)
Edited by Busky2k
Yeah must be an SR thing. Power in any gear. :) Or.. I again need a bigger turbo :)
I guess by dropping the boost back and getting the same load, that means that your boost is tapering up top? So just a phatter midrage with larger boost... Still cool I say. :)
Sorry I didn't mean the same load as when the boost was up, I dropped boost as with the higher boost level I can't get the power down in first, second even third tends to spin up a little when the diff decides its going to open wheel a tad causing less traction on the other so they both eventually go. :(
But yes the peak lower boost voltage 3rd and 4th appeared to be the same, first was a tad less than second but still spun slightly, second hooked up completely and was still tad less than third. Which was smack on 4v on the Z32. When I say a tad i mean 3.95v vs 4v. :P
3rd gear usually produces slightly less than 4th gear, say 2 to 3 kw. This is due to the more load on the engine in 4th and the slightly longer time to complete the run allowing the turbo to work a bit more.
We do a lot of NA holdens as well and with similar differences of 2 to 3 kw between gears.
Cheers,
Mike
The Shootout parameter, IT (intake temp) is 55C. That would overinflate your readings by a good amount.
Cheers
PS on a side note, since when did R33s reach 180kmh in 3rd gear lol.
so you're saying the dyno operator made an error?
he had the inlet temp sensor where i've indicated in the photo...he was telling me how not many dyno operators do that, but how it gives the most accurate readout!
If what you are saying is true then the fan would have been hammering the snorkle with clean air that is not 55degree's.
The only other explaination is that the room really was 55degree's but he had the AT sensor located in the fridge or outside. :laugh:
I've never had a dyno run where the IT and AT readings are much different, the interesting thing is the dyno I run on is situated at the back of a workshop that gets no fresh air. Its actually pretty badly setup with regards to the lack of fresh air as after a tune my eyes sting for ages. :O
hmmm it was definitely not 55 degrees in the workshop :P
I think it can be put down to incompetence, just as i initially thought
Maybe the plastic was hot? Transfered a little temp to the sensor or something.
A temp difference doesn't mean he's incompentant.. but do quiz him next time the car is in there as to why the inlet temp is so high.
i quizzed him as to how a car with a 187kw engine could make 182rwkw at the wheels
he told me
"you never know whats under the heatshield of one of these things"
I said, yeah I do...its stock....
he just kept trying to tell me that I have some mystery mod, which I dont have.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
