Noticed an ad in HPI #67 for an Australian company called Cre8tec. The product they were advertising was the 'Electronic Supercharger' Wich they claim can increase engine torque by up to 20%!! Umongst other things. Has anyone used this product? Is it probable that it could help with increasing turbo response?
Also have heard stories of slightly increased turbo response from installing Earthing kits. These are getting cheap now days.
Thoughts and experiences please :laugh:
Edit: btw I'm not a ricer.. Just the idea of possible cheap/easy lag reducing products interests me :D
BELOW IS A PIC OF THE ELECTRONIC SUPERCHARGER
Edited by Drift_Limo
Why would you buy a product nobody uses,and for good reason,when you could just turn up the boost? Not to mention setup time getting it to work.Any electronicly dependent product will also drain your battery a lot faster as I believe that is just a hi-speed fan.Don`t waste your money.
Thirty years of throwing money down the drain at things that don`t work or make so little difference that it will, and I mean WILL end up on an already crowded shelf in the deep dark corner of your garage.Take my advice only if you want to but please watch what others do and if they have found something that works,copy them.Being the first to do anything is overated.
Your right in that he did not understand the actual product you mentioned, but unfortunately you do not either, as his advice applies in equal messure to the outrageous claims made by this device.
Do not confuse this "Electronic Supercharger!??" Black box with two or three wires ( NOT that other fan type from UK ) against a valid product such as the "Electronic Earthing Kit"
The electronic earthing kit has merrit in that it just allows for a decent earth return around your engine and ancilaries. BTW I have done this myself by just buying some longer battery style cables and bolting on in a few places on the engine / chassis, Its JUST a GOOD EARTH!
The other "Electronic Supercharger" is possibly similar to the products exposed by ZOOM some time ago.
Now more importantly, can I interest you in 120 Million USD I have been left by an uncle who once lived in Nigeria and inherited a Diamond Mine? Just send me your bank account det...........
LOL let me make it clear that I am almost as skeptical as you guys
Wich is why I posted the topic.. Unfortunatly you were unable to explain in further detail how it works (or is meant to)
Yes. Maybe you could mention if you noticed a change in engine behavior?
I would rather save the hassle and pay the extra $20+
Wouldn't it be smarter to send me your account details? So I can deposit the money into your account? :D
Thoughts and experiences please :D
Hey there..I have read a little about those and really dont know how they work.Though I was surprised that theres a electronic cupercharger kit for sale for a celica thats part of the aftermarket air intake kit..its boxy shaped and real small (cant see no belts or nothing like those normal superchargers)and its fitted right after the air intake.And theres supposedly some power and torque gains from those but havnt been proven and ive never met anyone whos had them installed.Nor any other article that supports that product.
Funnily enough..I was told by a mate (who knows his sh*t about supras) about electronic turbochargers which are a cheap option for power gains but can only boost up to 5psi.Anyone else head of them?
Havnt heard much about slightly increased turbo response from installing Earth kits..like someone else said its just good earthing as time will wear away everything on cars..its just wise to install better earthing kits.There are some gains.
Um i remember reading about thema long time ago on SDU..megala asked about them,heres the link.
http://www.skylinesdownunder.com/forums/se...?searchid=43191
Hope that helps..But in the end,do some serious research into them as you dont want to end up spending money on something thats just nothing.
From what I understand about electric superchargers & turbos is that the majority of them are aimed at smaller NA vehicles that want a little kick for a short amount of time by increasing intake by 1 or 2 psi.
They also require a lot of current to drive them and so having any more than short bursts will quickly deplete your battery.
Some of them have an auxillary battery, but then it only increases the amount of time you can have the motor on. I.e. no good for track work.
Other people have tried taking current directly from the alternator but what gains you make through increase air you lose through additional load on the engine due to the load on the alternator.
What people should look at is using an electric motor to assist the spooling up of large turbos, but then let the exhuast drive the turbine normally.
What people should look at is NOT BOTHERING WITH SHIT
here i fixed it up for you! (no im not haveing a stab at you)
seriously DONT f**kING BOTHER, the bastards that make that shit need their heads kicked in for selling crap that does nothing. thats right IT DOES NOTHING.
those things cant flow near enough air to make ent difference, infact your better off getting 10 computer fans and makeing a stack of them and using them in your intake, it will probably do better than the mentioned product
.. yeah I was just being polite about it :D
LOL I swear I'm going to be labelled a ricer after this :D I think a couple of you guys are getting this product mixed up with an actual external electricly powered supercharger (lol). No way would I consider paying for such a product.
BTW the top model rrp for the electronic supercharger is $999!!!!! Even if it did prove to work I'm unsure if the costs (+ installation for some) would really be worth it
http://www.cre8tec.com.au/product/main_view.php?pid=27
i have seen and read about some electronic turbo charged applications. Which run off the battery to compress air instead of exhaust gasses... Supercharger is probably a more politically correct termination for them
Not sure if this is the same thing your talking about but..
Basically any claims are way exagerrated and for the money these things are far from worth it.. But i suppose they do work, i read somewhere in a magazine that they run 2psi.. 2psi is better than standard atmospheric pressure i suppose but, well, most ricers in 4 cylinder magazines (perhaps i wanted a honda civic b4 i wanted a skyline, cant quite remember why i picked one up) boasted of horsepower increases, of something like 10hp.. They cost around $600-$900 so.. waste of money
Maybe itd have a wine though... You could set up a BOV somehow i guess with a switch here and a relay there.. If that would work then theres a massive pull for the rice factor.. but with N/A BOV's out now who knows ^^
Edited by r32 gts-turbo
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
