GTR injectors should be ok, but they are usually overpriced, and you will still need to modify them from low impedance to high impedance. RX7 injectors are usually more cost effective.
  • 8 months later...
  • Replies 58
so the 13b's are not a direct replacement for the stockies?
BTW. what are the CC's for stockies on a ER34???
Just a point of interest for the 34 injectors, I know SK has tested them to be around the same as 33 injectors, but just for reference sake: from HPI #32 (Project R34 article)
"the std injectors on the RB25DET Neo engine are only 340cc/min... ...Unfortunately Nissan chose to update this engine with the skinny new plastic bosch inectors, so aftermarket options are limited."
600hp is 447kW.
At the crank that's a damn lot.
I would imagine 660-740cc would be better but then your car idles bad.
550cc will be fine for ~450hp crank situations.
btw. where the hell are you getting these prices for the cheap RX7 injectors and rails?
My next choice is the Nismo 555cc and they are pretty much $1,000 delivered.
Any contact for the cheap injectors and rail? Hook a brutha up :P
T.
Where can u get a set of nismo 555cc injectors for $1000 delivered?
wld747, do you want your car to be able to idle properly? If not, go the 850cc injectors.
these links I found pretty handy when considering injector upgrades:
http://www.ap-engineering.co.jp/el/inj_side.htm
they also have a page for top feed injectors, but cant find it at the moment, will post up later
here it is:
http://www.ap-engineering.co.jp/el/inj_top.htm
thanks steve i didnt realise that with bigger injectors idle becomes stuffed.
here it is:
Has anyone tried to control bigger injectors with a SAFC??
does it work?
The SAFC doesn't control anything! The ECU does that, the SAFC just bends the input signals to the ECU. So the question should be ................
Has anyone tried to control bigger injectors with the standard ECU?
Yes, and it doesn't work too well, cruise and idle are the problem, as is hot start.
Interesting thread. I have had my finger on this pulse for some time now. Before this old thread was dug up, I found out about Cosmo injectors here.
http://www.nissansilvia.co.nz/tech/howtous...0Binjectors.htm
All the lowdown you guys are seeking !
very interesting facts bigdatto, Thanks :)
Also for a mild and tunable upgrade could you use CA18DET inj. at 370-380cc or RB26DETT inj. at 444cc? thanks
I know the GTR injectors need the resistor pack wired in but what about the CA18det injectors? are they a direct bolt in job?
  • 4 weeks later...
Hi Guys does anyone know the part number of the 13B and 20B injectors? I have found a set of 550 cc injectors that are side feed supposedly from a "Mazda". The part number is OF555-425 with a batch code of A40-00. The suspicion is based on the colour, they are red'ish brown, not purple as in the Silvia guide above.
The part no. for side feed 13B/20B 550cc is 195500-2460. These are purple top and are found in the 13B-REW (series 6 RX7), not the 13BT (series 5 and below which are top feed). They are also in the 20B Cosmo. I'm told all 6 are 550cc, but only 3 are side feed. I'm trying to confirm that the 20B's have the same part no. as the 13B-REW's.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
