Maintenance is no big issue with any Skyline really.
As long as the oil and filter is changed regularly along with a normal service routine they will just run forever if treated well.
I ran synthetic oil in mine changed every 5000kms but 10,000km intervals is OK under normal conditions.
Good thing about Nissans is a lot of Parts are interchangeable to many other models. For instance an R33 power antenna is interchangeable with a Maxima one etc etc....makes sence to do it but a lot of manufacturers don't .
If you're after new parts see Steve at Northside Nissan parts.
He knows and loves Skylines (owns a 33) and is also happy to import any Nismo parts you want/can afford.
Do you have a mechanic you know and trust?
If not what part of Perth you from so someone can recommend a local
Cheers
Chris
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224660
Is the R33 skyline oil filter interchangable with Maxima as well?
I heard the front wheel bearings are interchangeable.
Seems like Maxima is the closest parts bin for skyline, I suppose due to the similar gross weight range and engine cylinders/capacity? But one is V6 3.0 and the other is I6 2.5
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224683
For oil filter good old R31 will fit.
Maxima would not be a likely donor for Skyline mechanical parts.
Although i think the wheels fit
One is a brilliant sports sedan the other is a...well a Maxima.
I only used that example to indicate that Nissan tries to keep a high level of part interchangability.
For another instance the Skyline has 300zx front suspension and 200sx rear so I'm told
Cheers
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224695
Originally posted by eriktufa
Rotomotion? I'm not sure, never heard of it.
How bout around Curtin, Bentley?
Wow are you sure the parts of Maxima similar?
If that true so I wont' have any problem getting parts for it
Curtin, Bentley that's easy C-Red or SST they both know their stuff.
Talk to them.
Cheers
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224700
C-Red and SST , where can i find those 2 shops?
And I got a problem the head light cover (glass), I don't know how to describe it, It seems dirty and blurry , I'm thinking to get a new one but not the light just the cover. What is it called?
Heherheheheh I don't know the name
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224726
I did an oil change on sunday, used a VL commo oil filter from marlows, cost me $8.
Maxima mechanical parts are a no-no.
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224774
Im sure you can polish the headlight covers using some braso, cleans it up like new. To replace them will cost heaps.
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-224779
So obviously they didn't fit new halogen headlights as they are supposed to do for compliancing the naughty boys.
Nevermind the Xeon ones are far superior.
For the details on C-Red and SST just look in the white pages we can't do it all for you.
Cheers
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-225340
i keep trying to tell ppl to use toothpaste on your headlights, hehehe, its something most ppl have already got in the house, so saves you having to go and buy something and it works real good too, mine were discusting then i used toothpaste and they came up brandnew. ;)
my 2c.
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-225442
Guys where can I service my car? and how regular is it?
Ah Ic, how do u remove the cover by urself?
Where can I buy braso?
Arrrghhh! Is this a troll? We need these questions answered like I need a hole in the head.
eriktufa, if you arn't trolling (and don't ask "what is a troll?"), use the fcuking search button. Most of these topics have been discussed within the last 2 weeks!.
https://www.sau.com.au/forums/topic/12392-maintenance-r34/#findComment-225571
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
