I can buy new ACL for $1100 or JE pistons for $1200 or second hand Wiseco for half that but when you factor in new rings it's not such a big saving.
Can I buy them at a better price elsewhere or look at some other brand?
Dont bother buying second hand, usually more trouble than they are worth.
ACL are good value, CP are also an excellent piston.
you have to look at the power level your chasing. acl may be good value, but will they take 700hp worth of punishment? doubt it. ive used acl pistons before, and dont get me wrong, theyr great. but you have to do a complete package, not just pick and choose parts, as one part may be a weak link in the chain, and fail destroying your motor.
and dont go second hand, many drag motors have pull downs every few 100kms, but they do get punished in that period, and may be ready to fail.
Edited by ezi09s
Remember sizing aswell.
Forgies might not suit your motor if you havent got it apart yet and know what size you actually need :)
No point getting them @ 86mm and then your needing 87mm :wub:
And you wont know that till its all machined and inspected etc etc
couldnt you sleeve the bores?
nothing wrong with used pistons, dependent on condition etc... but probably not worth the potential hassle; spend the ca$h on newies IMO.
But why sleeve if you can purchase something off the shelf.
By the time you spend the $$$ having it sleeved etc.
You'd probably have a new set of pistons in there or within $200 or so of it like you said :)
I personally know my choice on the matter - new.
CP are the shit. but any piston can fail. dont think because they are forged that you cant break them. i torched a $1200 set of Ross pistons in the Galant due to an alternator failure, yes $300 each, very upset but i learnt my lesson.
Edited by BezerkR32
Asinine comment removed - make sense or go away. :)
Yeah I'm a bit concerned about going 2nd hand.
5000k might be low ks but it's a lot of 10 second passes.
I'm not looking for huge power and stock pistons would be fine for my current needs but the motor was n/a so I need other pistons to lower the compression ratio and to raise the pin height to accommodate the rb26 crank.
I considered buying 2nd hand stock rb26 pistons and running them in the original bore but as the block doesn't have the oil squirters I was advised to use forged pistons or at least have the stockies ceramic coated.
Although the bores are quite good I'd feel better with a fresh bore.
I'm planning going 87mm straight up. I'm not worried about leaving any for a further rebuild as 2nd hand blocks are cheap.
How good are the JE pistons?
no need to be a smart arse, this was about 6 years ago and i was using a fuel only F3 Haltech and running methanol. push engine as hard as i do and we will see if your liitle computer will save your engine. the point is a forged piston can fail, regardless of the cause, fuel pump, injector alternator etc. if you are posting to give the guy advise and help answer his question its all good. if you post is off topic and your just trying to piss someone off, well congratulations you have succeeded. as it seems you have all the answers and obviously havent broken anything how about forwarding the guy some of your knowledge, otherwise suggest moderators do there job and delete posts that are off topic and that are a deliberate shitstir.
Off topic, vague nonsense
I've heard good and bad things about most brands of forgies.
I'm sure for my moderate application they all would be ok so I guess it really comes down to price and JE and ACL seem to be a few hundred cheaper than the others unless I'm not looking in the right places.
Any suggestions?
The point of my comment was that if your deciding to build an engine than its obvious that you are probably at a level of power that needs a decent ECU. ie one that has battery compensations. What was the lesson learnt?
The alternator dying on the Galant caused the voltage to the fuel pumps to drop and the lean-out condition killed the engine.
It was a fuel only computer back in the day when full ECU's were lots of $$$.
No-one buys fuel only ecu's these days do they?
Anyway.......Pistons!
Adrian
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
