Where and how is the best place to mount a video camera in a gtr? I have no roll cage to strap it to....the car is just standard on the inside. While we're on the topic, has anyone used one of the mini dvd video cameras for onboard video? does the recording stuff up when you're flying around the track and hitting bumps?
https://www.sau.com.au/forums/topic/124164-onboard-cameras/
Ok. time to show some ignorance of what the inside if a GTR looks like, but does it have grab handles in the rear (the ones just above the window)?
I have seen other cars with a mount made that bolts to the handle mount points and runs across behind the front seats, so the camera sits at shoulder height just between the seats. Easy enough to put in and remove.
I have also seen some one with a fairly new hard disk camcorder that was small and light, he had sticky backed velcro on the bottom of the camera and on the dash, which held well enough for spirited drives down the GOR (not much use for track work though, the scrutineers wouldn't be too happy with it).
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2293975
Get a Manfrodo suction mount.
Stick suction cap to back window.
Perfect
If he's using it on the track, would a suction mount make it past the scrutineers?
Google comes up with a few ideas...
http://www.camerahacker.com/Car_Camera_Mount/index.shtml
http://www.stickypod.com/ (scrutineers would love this one as well!)
This might be OK, but only if you have adjustable head restraints. http://www.ae92gts.com/ae92gts_video_mount.html
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2294869
I have seen the mounts which the WRX guys use.
It goes between the Jesus handles in the back of the car and suspends the camera above the centre seat in the rear.
I might make some....
But I know that in Targa you can run suction pods inside the car and it's no problem.
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2294952
Thats what I was trying to describe, I'll stick a post up on Rex site seeing if anyone has any pictures of the mount.
Fastening a mount to the baby seat fixing points also has merit I reckon.
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2295339
would love to hear more about the suspended one between the seats cause i'd love the camera to sit as close to my left shoulder as possible.....to get a view of the gauges as well as out the front windscreen.
Your wish is my command :D
A few pics taken by someone in the Rex club for me......
Camera mount 1
Camera mount 2
Camera mount 3
Camera mount 4
Camera mount 5
Also some in car footage taken from one (Stolen from Highlife on the WRX.com.au forums)......
Right click and save (Warning broadband only ~30MB)
Edited by wokka wokka
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2303451
There's probably a good market for these mounts if someone could develop a professional mount like these for the skylines too. You would only have to make 3 different variants for each model (32,33,34) as GTS-T and GTR mount spots would be identical. I might look into this!
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2303527
ok, probably a bit off topic,, but may help someone in some way
I have a double din head unit in my car,
it has reversing camera input,, and also AUX input (yellow,red,white rca's)
So,, what I did was hook up a reversing camera (with night vision)
and hooked up a front camera (front bumper cam), and hooked it up through the AUX input,,
now these camera's don't have sound,, but u can get ones with sound but I was on a budget,,,
with my head unit, I can go into aux mode, and watch "front bumper cam",, and by pressing a button on the remote, I can switch to rear bumper cam,, and back and forth (its more of a novelty for the passengers but you get the idea,, also rear camera helps with reversing at night time),,, also the head unit has Video output,, so I'm thinking I'll hook it up to a laptop and record the video footage (that's if its actually that simple,, haven't tried yet),,, so yeah,, that's how I did my in-car camera setup,,
front and rear are both colour camera's with night vision in black and white.. head unit is out at the moment,, otherwise I would have taken pics of the setup and shown what the footage looks like on the screen..
both cameras are ccd,, would have used cmos (quality of colour footage is much better with cmos) but they were more expensive back then,,,
grey (mine is a bronze colour) camera is what i used as front bumper cam (did not buy wireless receiver)
and black one is what i used as rear bumper cam
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2303687
OK...just had someone check my car and is has the jesus bars in the rear. So my question is who wants to make these mounts for a gtr? i'm sure i'm not the only person that would buy one so i'm sure you could make a decent amount of money from it.
Edited by tk80
https://www.sau.com.au/forums/topic/124164-onboard-cameras/#findComment-2307490
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
