  • Replies 189
top day thanks pete!
i might learn the art of skid control sometime in the next 10years.. but until then you can find me on the black stuff.... or at least on the brown stuff next to the black stuff.
c'mon steve! make with the action pics! There seems to be an awful lot of parked cars there!
so I take it everything went well.
NOW I WANT SOME SIDEWAYS PICS!
haha, sorry mate, i dont have many good action shots, ill have a look whats left on the camera for you tommorrow :D
drove better? hahaahah funnies thing ive heard :P
Mitch - you got msn?
Steve - Photos of my nice clean car now? or the ones you and Vic took?
Vic - how was the ride?
The ones we took :)
LOL Lucky ya sneaked a ride in for me :mad: $100 in your bank account right now >_<
Thanks man!
Ride was good, reminds me of me going off track at wakie..
Steve split a shitbox next time so we can all give it ago :O
Most of the ride I was like..
Fkn fantastic day Pete! I had an absolute ball, except for the bit where I popped a piston in my wife's Forester. My balls are still intact, but every night is a new adventure. I've hidden all the sharp knives. :lol:
It was great to meet and catch up with you guys/gals from this forum. I've gotta say it seemed like we had a great bunch of people out there.
What I found most enjoyable was the complete lack of the whole "them v's us" shit that seems to happen when you get 2 different bunches of car enthusiasts together (like Subaru fans and Nissan fans). I think there was a healthy respect of everyone else's rides out there, regardless of the the badges. I know the guys in the WRXs really enjoyed the day and have been raving about it on the club forum.
Thanks again Pete. Top day was had by all..(except my wife LOL).
Cheers,
Ben
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
