I have this problem with my clutch, unsure if its a single or twin plate. was told it was a twin plate by the guy i bought the car from, Anyway when i put my foot on the clutch it feels normal, abit heavy i guess. then sometimes when i slip the clutch abit to take off the clutch goes real light for bit then after a few seconds of driving goes back to feeling normal. Anyone experincd this? my car is a r32 gtr
Cheers
https://www.sau.com.au/forums/topic/124272-clutch-problem/
ah ok cheers, its weird you can pup the pedal a hunded time when you staionary and t stays the same, its only when you slip it abit t take off sometimes it does it, not all the times. Doesnt seem to have any leaks or down on fluid.
https://www.sau.com.au/forums/topic/124272-clutch-problem/#findComment-2297900
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
