I took my turbo smart boost controller out bcoz the police told me to otherwise its a $300 fine.
Just wondering does the boost controller have to be in the engine bay?
Can I install it under the dash somewhere and run the line into the engine bay into the actuator.
Or is the length of the hose critical that is connected to the controller and actuator?
Also my Autometre boost gauge always needs calibration after 3 months or so...which means i have take it out of the dash and pull the dash apart to get in behind it to calibrate it. Any suggestions or similar problems.
I Also need an air box made up to fit around my Blitz pod filter. Any suggestions in Sydney?
lol suprised the boys in blue knew what to look for, havent got one but a few mates run them and havent had any trouble as yet , i thought you could get in car digital ones that you could up and down at a push of a button
in both cases, electronic or gated, you can run a hose into the dash.
a 2m or so added length to the hose wont affect the performance etc..
turbosmart sell a 2 stage in cabin unit, which has vaccum lines from the wastegate to the cabin, then to the manifold. that short of a distance should do nothing
my waste gate has one tube in the middle of it going to the intake manifold but it also has a connection on the back of the wastegate for another tube where would this go to ?
is it an internal or external gate?
ok 4 sum reason i cant upload, so il try n explain it.
the top pipe goes to your solenoid, and the other pipe goes to a "t" peice. this then goes to the other side of the solenoid and to the manifold.
comprende?
comprende?
yeah i understand ,the top one on this goes to a T which splits it to the boost gauge and to the manifold the one on the rear of the WG doesnt have a pipe going anywhere just the fitting
The less hose there is between the bleeder the better.
My bleeder was very close to the turbo for a while, not a spike.
Ive seen other "in cabin" jobs and they are appaling.
Either way, the police these days are not stupid (i assume you are in Vic)
I would just take the car to a workshop and have the actuator modified to run a higher boost level for minor applications
I was told by a cop to remove my ebc one day, i rang transport and they said it was fine.
Called the cop back and left a message to call me, suprise suprise he never called me back.
I am in qld, dont know about victoria though.
I would never use a simple bleeder, grab a pfc and the boost control kit for that. You should be able to hide it pretty well!
Whats wrong with using a bleeder?
Dont know what experience you have had with ebc's but mine have been all good.
I wound never use something as cheap and coarse and a bleeder i also like the ebc's ability to bring boost on a little faster!
If the budget allows i would always grab a ebc, but yes there are some out there that are a little dodgy.
I have used profec b, and profec b spec II, for my 26/30 i will use a pfc and the pfc bc kit.
Well see how it goes.
However i will be the first to admit it can take some time to set an ebc up perfectly!
If your labelling a bleeder dodgy, you have NFI what you are talking about :D
I've never used an EBC. Bleeders since day one.
EBC's are nice, bleeders are nice.
To say one is dodgy is just wrong
As i said i feel they are a little coarse, and cannot bring boost on earlier as a ebc can.
I also said that some ebcs are a little dodgy, does this mean i have NFI what im talking about?
I suspect that it people are having problems with ebcs that are known to do the job well then perhaps they need to look at uprgading from the stock actuator to bring their mechanical boost level closer to their desired higher ebc boost level.
i dont reckon an EBC can bring boost on earlier compared to a bleeder.
I certainly didnt have boost delivery issues
With an ebc you can adjust when the wastegate starts to open, this brings boost on faster than a bleeder. If you set this to close to your desired boost level if will spike. You must find a good compromise which is the difference between a well setup ebc and one that isnt.
The greddy profec b spec 2 can also limit boost spiking. eg i have it set to 1.18 bar as i dont want it to go over 1.17. This feature is really handy when setting it up.
Maybe give one a try someday, you could always sell it if you dont like it.
If you have a pfc i think it would be silly not to run their pfc ebc kit.
Also i wasnt saying you were having boost delivery issues.
Mick
EBC vs a Bleeder, I have a Turbosmart boost Tee I have no problems with it, if you hit the Accelerator hard a 5000rpm it spikes only .5 psi and it is conected after the coola. is spikeing all that bad, $80 to $400 I think the Bleeder does fine.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
