I just purchased some rims that came with new Falken RT 615 semi comps in soft compound on the rear. I was intending them to be circuit rubber but I was also going to make my way down to Calder soon and was wondering how they would go as a drag tire... specifically what psi should I have in them and how long do I need to smoke them for to get the right amount of heat?
I know they are a relatively new tire so nobody may have specific experience with them but any comments/advice would be appreciated. :huh:
https://www.sau.com.au/forums/topic/124435-falken-semi-comps-as-a-drag-tire/
circuit tyres dont work at all well as drag tyres.
The sidewalls are hard, and have no flex.
You'd be better off on the street tyres, using 20-24psi in them which will give more traction that a hard walled semi that wont have much play at all.
RT215 / RT615's are a street tyre not a semi, but have a stiffer sidewall than most road tyres. Their treadwear rating is 180-200.
Semi slick 'R' compound tyres eg Bridgestone RE55s, Toyo RA888, Yoko A032R are 60-80 treadwear.
The Falkens should grip better than most street tyres though.
Edited by VHR32
Whilst I'm no drag racer, I have absolutely no doubt that semis will hook up better than your regular road tyres. My experiences on both (Bridgestones verus Azeni RT215 255/40/17) is that the car is all over the road on the bridgestones, and much more composed on the semis.
Only problem is you don't get an awful lot of KM out of them :)
haha geez thanks for all agreeing guys... something to think about I guess... in answer to VHR32 they are definately an 'R' compound semi race tire but yes they have a treadwear rating of 200 which makes them the most streetable of the semis but also I would imagine slower ona track compared to RE55s etc... but thats why I am using them daily rather than keeping them in the shed (I only drive like 2kms to work and back)...
if anyone is interested they are lovely to drive on the street with, nice and quiet, great in the wet, they also tramline less than other tires I have had... only downside so far is they are worse in choppy side streets as they don't soak up the bumps as well but an okay trade off when you go round a corner and they don't try and roll onto the tires shoulder blah blah... anyway I am very happy, might even take a regular tired set to Calder and do a back to back comparison
There is nothing R compound about a tyre with a treadwear rating of 200! Falken have long been producing tyres that look like R compound tyres but aren't. A proper set of R coumpounds are night and day by comparison to the Falkens.
I have driven on Azenis RT215, Hankook Z2000, Yokohama A032R, Brigestone RE55S, Toyo RA01. The Azenis are not a true R compound tyre. They are only a marginal improvement over a normal street tyre. There is no real improvement in outright grip levels, but they are much more responsive and consistent due to the sidewall construction and larger treadblocks.
but if you want a tyes for the drags, why not get ones designed for that?
yes you are right harry. I think people above are confusing a 'semi slick' with an R-compound (aka S-tyre). the falkens are most certainly a semi-slick. ie they have a semi slick style tread pattern which is completely different to a conventional road tyre. they also have stiff, square sidewalls. however they are not made from an R-compound rubber.
I didn't get them for drags I got them as an everday/circuit tire... mate has been wanting to go to Calder recently and I was wondering if I should leave them on or trash and old set...
as for outright grip levels I would have to agree they are only marginally better than the Michelin Pilot sports (best tire I have had on to compare with) but as you have stated the feel and sidewall make for a much more predictable drive... I should really reserve judgement tho, as I haven't pushed them on a track yet
ah okay, I will cease to refer to them as R compound :nyaanyaa:
personally, I wouldn't even call them semi slicks. People use the terms semi slick, R compound, etc interchangably when referring to soft compound competition tyres. Semi slick is about more than the tread pattern to most people - its about a tyre halfway between a street tyre and a slick, and that's more than just a flash race looking tread pattern - its about how they perform.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
