I took my GTR to calder park drags today and first run went fine but on my second run towards the end the oil pressure gauge dropped to zero and red light came on. and car felt weird towards end of the run.
my friend reckons there was a big cloud of black smoke from my exhaust.
Anyway pulled over and car was running and sounding weird, like it wanted to stall and it did a few times.
checked oil level and it was ok. I let the car cool down for a few hours and checked oil again seemed fine but when I started the car the oil pressure red warning light was on again.
Lifters and tappets were noisy like no oil was circulating to the top of the engine.
So I had no choice but to drive it home real slow at low revs and right as I got home it stalled in my driveway and wont start now.
What I want to know is does this sound like my oil pump is gone and not pumping or
plugs fouled or both. when it first happened car did start but now it won't and I'm confused.
would a stuffed oil pump affect the car starting at all?
Any help or ideas would be appreciated
Thanks
Edited by >GoDziLLa<
https://www.sau.com.au/forums/topic/124508-is-my-oil-pump-dead-weird-problem/
stuffed oil pump will cause no oil on the bearings... no oil on the bearings means no lubrictaion
= spun bearings = rebuild time
hope thats not the case though
--- do you mean fuel pressure or oil pressure in the first line??
no oil cam cause the cams to seize aswell ... you shouldn't have driven it home IMO
I was talking about no oil pressure and yes the engine does crank over but it just doesnt start,
damn I hope it hasnt seized keeping in mind it only took me 5 mins to get home. Its like when the car has no fuel and just doesnt want to start but Its got fuel in there.
That is called no compression hate to be bearer of bad news
yeah 99% you've blown the motor, and you were damn lucky not to sieze it as well. a compression test can confirm for you since the starter motor can still turn it.
and if the motor has run for a while after the pump died you will need to budget for a new bottom and and possibly head, everything will be rooted (block, crank, pistons etc)
ummmm. please dont test it :) its alreaddy f**ked im sory to say.
that ltlle red light has to come on for about 1 second at full boost to destroy a motor.
just park it and start looking for a bottom end. sory to be blunt but theres no way a motor could survive that.
good luck with the rebuild
I did try to start it again today but as someone said theres no compresssion so I guess Im screwed.
I have a brand new fully forged RB30 bottom end with arias pistons and ACL race bearings that I was gonna put into my VL, how hard would it be to use that on the GTR and make it 3 litre?
Also what are the chances that I damaged the head as well or any way to check.
Don't know how helpful this is to the topic.. My RB25 blew an oil hose and was ran without oil to the point of the exhaust cam seizing. It still runs fine on 4 cyls with an A/M ecu on base maps :(
I will be pulling it down to check the bearings and give it a freshen up at the same time. Head is goneskis though.
the rb30 bottom end is perfect, check out the recent rb30/26 in a gtr thread you will find all the infor you need. main thing is a sump adapter plate which you can buy from fitzpatrick speed works on here.
ummmm. please dont test it :( its alreaddy f**ked im sory to say.
Not always, I have seen the light come on when the vehicle had an alternator problem. Replaced alternator, light went out. Manual oil pressure test confirmed no problems.
Although this was a one in a million chance it still happened that way. Had me baffled for quite some time.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
