hey guys was just wondering what engine you think would be more suitable for drifting a 180sx a RB25DET or the SR20DET need help as mate thinks sr20 would drift better where i think rb25...lol
cheers adam...
Edited by Bo05t3d
https://www.sau.com.au/forums/topic/124569-drift-spec-180sx-rb25det-or-sr20det/
Go an Ecotec.
But seriously, for most people the SR20DET gives enough power and response to get drifting. It's cheaper and gives better weight distrobution than the RB. Only in really extreme drift would the extra power, torque and response of the RB be worthwhile.
Just my 2c
Edited by Big Rizza
Your mate and the Big R is right.. Not only is the RB25 heavier but it locates the weight further forward of the crossmember.
A VQ30 on the other hand :whistling:
That thing barely fits into a 300ZX. How the hell do you squeeze it into an S13? Very wide engine for such a small vehicle...
Your're getting the VG and the VQ series(alloy block) mixed up.. And I have seen a VG30 in a 180. Also my mate had a VQ30 in a Laurel. Was a nice fit. Banzai motorsports recently bought it as a project car. I've heard rumors of that VQ30's are lighter than RB25's. Also the single stock turbo of the VQ being of steel wheel config gives the possibility of 220rwkw :whistling:
But yeah any V layout engine in an S13 will probably create under bonnet temp issues.
i'd probably say rb20. slightly more torque than a sr20, so if you were to go into a corner, or come out of a corner, lower in the rev range the more torque would still be able to keep the wheels spinning. but it really comes down to what mods you are going to run on the engine. if it is going to be reasonably stock then the sr20 won't be as good as the rb20 because the sr takes a while to spool up due to the bush bearing turbo. however to use an rb motor you would need to change to a steel wheeled turbo, otherwise you will cook it.
Thats just plain, WRONG...the RB20DET has no torque compaired to the SR20DET...i should know, ive owned both!
The SR has heaps more low down compaired to the RB20...expecially when going for a larger turbo
SR is the pick of the bunch for an S13...but sounds like a tractor....RB note is insane!
An RB25 will have more torque though (which was the original question, and I think / hope mad082 just typo'ed).
That said, you want a well balanced car and an RB powered Silvia won't be as well balanced as an SR powered one.
were they in the same car? the r32 is a heavier car than a silvia or 180. i have driven a silvia with an rb20 motor in it, and i used to own a 180sx with an sr20. the rb20 had more low down power then the sr20. out of a slow corner the rb would pull a lot earlier in the revs. but out of a slow corner the missus' natro sr20 pulsar would beat both of them until they got up in the revs.
and i'm talking about stock motors with stock turbos, just front mounts and exhausts.
Edited by mad082
LOL!
The RB20 has no torque.
It's a 6, where the SR20 is a 4 cyl.
on the topic, whats the weight difference between an rb20 and rb25?
Would having one in a 32 make a huge difference to the weight distribution of the car?
You'll actually be suprised, but a significant portion of the difference in weight between an r32 and r33 is actually the motor and gearbox.
This goes to all of those homos calling r33s boats. I'm not just making this up off the top of my head. I did an rb25 into r ugly poo (32). After helpinng a friend out with an rb25 swap into his r ugly poo, it weighed almost as much as an r33 gtst.
So basically, to all you r32 lovers, the reason why your car is lighter is mainly because of the crap motor and crap gearbox.
Edited by MANWHOR3
Lol so much hostility dude,
They also bag our cars on the looks & how it's all bulgy, I love 33's In fact all of the skylines.
What's with all this competitiveness between r32/r33 owners? Aren't we all supposed to be united against power tripping cops & v8 bogans? :)
Why not hate on the R34 owners for owning better looking and faster cars than you? :)
[Flamesuit: ON]
There is no hostility or hatred going on here, just merely pointing out that most of the weight comes from superior parts, such as motor (and ancilliaries e.g. bigger fuel pump, bigger injectors, etc, every small thing adds weight) and much bigger box.
I was also merely pointing out that r ugly poo owners call r33s whales for being heavy when once these upgrades are installed into an r32, the weight is not that different, but at the end of the day, the interior still looks like a vn commo and the exterior is not far off a vl.
But in reply to the thread, sr20 since the car is designed for an sr. Much better/easier fit (an rb20/25 is really tight. try and find a pic of one). much better weight balance. plenty of power for the lighter car.
LOL is all I can do at that.
I drift my RB20 and no, it sucks, even my old CA18 Silvia had more torque down-low to mid which is where you most need it for drifting IMO. Apart from being annoying on the track, it's also annoying on the street as well, have to redline it just to take off from the lights at a reasonable rate. :P
I don't think anyone started bagging R33s in this thread but you straight out started to bag R32s just cause you felt like it in an unrelated topic. So because you've let your thoughts free, so will I even though they will be offensive.
Sorry but my interpretation is that whale is in reference to the whale-like appearance (small factor being weight). I knew the whales were much better value than the 32s when I bought my "ugly poo", but I wouldn't be able to live with the fact that when I stare at my car I see a whale on wheels. Ugly FAT things they are. But hey this is just my opinion and it shouldn't matter to you.
You know that is always in my mind when I think of R33s but you don't see me boasting around and bagging other models in any old unrelated topic with no mention of of it.
We all love Skylines, we should learn to be more opened minded and tolerant of other people's opinions/tastes, control yourselves guys. :D
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
