Hey
A guy from work is organising this event.... It going to be mainly a techno event with electro, minimal, tech house, breaks and DnB.
http://www.inthemix.com.au/whatson/event/31051/Eternity
http://www.dnanet.net
Tickets are only $18 + Booking fee from
Live
Planet Video
Mills Records
Ivinyl
The DJ Factory
Inthemix
https://www.sau.com.au/forums/topic/124616-eternity-heat-night-club-29th-july/
sounds good
but if u read on teknoscape, there's a lot of crap happening at heat lately, basically to do with poor management, dodgy security, not loud enough music (debatable, council regulations have a lot to do with it), people waiting 2 hrs in line, etc etc... refer to thread "heat nightclub".
i'll be at Heat this Saturday for Infusion Live though, see how it pans out.
sorry about the thread hijack, good luck with the event :D hell, i might even go :)
im gonna give heat a miss until they sort their stuff out :D
what happened not just one incident but many was farked :(
they cant even have the music up that loud.. you can have conversations on the dance floor and stuff :(
i dont see much tech around in perth either.
if tech's anything to go by i'd have to say the names of mauro picotto, carl cox and chris liebing would be worth seeing. picotto at subculture was a ripper last november.
if perth wasnt big in drum and bass imagine how low the recognition for perth's music would get...
If you like chris liebing or carl cox then this is the event for you. And also regards to the sound it has been sorted, as you might have seen from ts and inthemix from last nights event
yeh i was there (@ Heat last night for infusion)
was pretty good, one of the better bang-for-your-buck small-ish event i've been to for a while ;)
sound was good, bouncers were ok, no big line as far as i know... but they didnt open upstairs so it got quite packed around 1.30-3am.
He he he, a guy from work designed that poster and is filming some chick today dancing for the big screen promo...:P
Al will be there :)
Hey
Live
Planet Video
Mills Records
Ivinyl
The DJ Factory
Inthemix
yeh sooooooooooo down for parklife :P
that weekend's a killer hey, Godskitchen on the Saturday and Parklife on the Monday (someone say uni?)
GK's just got that gk vibe so dont think i can turn it down (Cosmic Gate, Above and Beyond, Eddie Halliwell and Matt Hardwick fyi)
Parklife's got the lineup i've been itching for (Stanton Warriors :), notables go to Krafty, Farina and Kenobi)
If i was going to Roni Size on Sunday @ Harbourside (i think) i'd be a dead man.
heat sucks...... still haven't got their fricken shit sorted..........
gig I was suppose to play at with a mate on friday night has now been cancelled due to double booking!!!!!!!!!! Just when I thought they were starting to get back on track *bahaha fat chance*
Yeah Heat was not a good venue on Saturday night - the bouncers where cockheads and they turned the sound down during the head lining act's set because of a noise complaint. It took the bass out of the music and people just left because of it.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
