  • Replies 89
it's not quite there yet.... still has the "Topic Subscription Reply Notification..." infront. Now it's including the thread title at the end.
Is it possible to 'remove' the 'Topic Sub....' etc?
cheers
daniel
  • 3 weeks later...
I'll have a look at the code sometime this week, last time it involved editing the templates and the code, so I'm guessing the same will have to be done this time too.
