  • Replies 640
Posted Images
Yeah wilch and I were laughing about that one... I went with a GTT and left with a GTR - WOOOHOOOO!!!!
wilch clocked a 2:04 without a car! Imagine what he'd be like with a car :/
The RX7 had a split fuel line. The reason the guys couldn't put the fire out probably is because the lines were on fire from front to back of the car.
I've been over to the RENEW website and they have been effusive with their thanks for the flaggies efforts. We all really appreciate you guys.
Here is the combined times. I slipped down to 13th in the end from 10th earlier.
Reedy snuck into the 1:53's, OZ close to 1:51 flat, the love boat stormed around in 1:44, Majanal did a 1:54 before his intercooler hose blew apart, he and Chris Easton showed what the RB30DET's are capable of. Both had low peak power and crappy tyres but put in some really good times. Good to see Ando in the sub 2 minute club too.
Check my new sig :/
Here is the rest of the times.
Thanks to Abo Bob and the Renew guys for organising the day. I had a great day.
The only thing that I didn't like was the fact that some of us n00bs to EC, that have only done one track day somewhere else previously, weren't allowed to go out in the morning with an experienced driver to learn the lines and the track.
I went out freaking scared after the first few long corners. My car felt like it was all over the place, that and I had someone right up my arse (who I let pass asap). I was seriously shaken up. My car felt so unstable in the first session. It really freaked me out, especially since there just seem to be walls everywhere.
Because of this I skipped my second session.
Anyway, after playing with the suspension and tyre pressures I went back out and had a ball despite the fact I that there are two corners which are after a couple of crests, one goes right and one goes left. I was pretty much guessing which was which.. Which is really bad. But hey, I guess that's what happens when you're put out there for your first time and are expected to be up to pace with everyone else.....
Regardless, I had a ball. So much fun. Soooo much fun. Sorry I didn't open her up and get her sideways near the guys at turn two. I didn't want to burn the tires this time around, I have no more monies for new ones after that Oran day!
Fear my massive legs!
and grrr to spelling my last name wrong. lol
Abo,
It was good to see your fastest lap of the day was actually the last one when we were dualing! Good work!
Yeah, interesting. I really need to get some in car footage the next time I am tailing you around a track. It's a surreal look as you are slipping around the place pushing a bit hard then regaining control within a single second because we are both doing between 100 and 200+ km/h and often within a 1-2 car lengths of each other as it's happening.
Adam/Paul Good to see you two battling it out was good to watch. Same with the two rx7's (car 1 and other one).
Saw Majanal wanting to drift around corner 4 but stopped. :laugh:
:laugh: What Stan has a GTR ? :laugh: lols
Nice work Ando in the Ceffy 1.58.
Oh how good was the A4? :laugh: So gracefull as it zoomed around.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
