yeh the arab videos are interesting, tho i dunno if its 'drifting'. they're all front wheel drives carrying alot of speed, with a little handbrake thrown in for good measure, dont get me wrong, im damn sure i couldnt do that like them, and its fun to watch, i just dont htink its drifting.
and as for the titles, crazy arab drift should be renamed 'stupid arabs stand on road side while different stupid arabs attempt to lose control of there cars at high speed'. a bit long but much more fitting
PS - just saw the one where the guy gets hit, and im sure that killed him, so yeah, my new title is even more fitting!
Edited by VB-
https://www.sau.com.au/forums/topic/125236-what-the/#findComment-2313775
Gets hit? I know there's one where one dude starts running, and the car slams the back of another parked car, but the guy didn't get hit.
As for police, I don't think they're as active as ours are. ;o)
The speeds they do this at are boggling though, hey!? And around trucks on main roads etc. Crazy =-]
https://www.sau.com.au/forums/topic/125236-what-the/#findComment-2314057
yes one of the videos shows a guy getting hit, the black sedan loses it and the guy tries to run but he gets collected by the car, and goes flying. im not doctor but im damn sure he didnt live
https://www.sau.com.au/forums/topic/125236-what-the/#findComment-2315724
Yeah Ive seen that clip of the guy getting hit cause he wasnt fast enough to get out of the way. Im pretty sure the guys dead as well due to the impact from the car which sends him flying quite far, crazy arabs haha.
Edited by JUNR34
https://www.sau.com.au/forums/topic/125236-what-the/#findComment-2315795
don't have a link, just have the video. will load it up sometime. it isn't actually on a street, its on a track. the cafe thought was just something that poped into my head.
but i just came across this shizzle. this guy is nuts. he gets it past 90 degrees then pulls it back....on an open road.
Edited by mad082
https://www.sau.com.au/forums/topic/125236-what-the/#findComment-2316055
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
