Hey guys and girls :D
Just wondering if anyone has pics of their, or anyone elses R34 Gtt's engine bay with FMIC cooler pipes installed. I'm getting mine done next week and i'm just wondering about the stock air box and air intake pipe. I am guesing they are no longer usable due to the pipes being too big and thus the air intake pipe being unsuable, which in turn stops the airbox getting an air feed. So i am thinking i will have to go for a pod with a head sheild or something, but thought perhaps someone had found a way to use the stock air box.
I'm after pics of either of these set ups, FMIC pipes and still using the airbox (and perhaps the air feed), or with a pod filter set up (with a heat sheild/box, or however you have done it).
Sean
Sean
My cooler returns to the stock pipes. I know many of the Jap brands do this with their kits. Various pics available in the link in my sig.
Yes mine is going to return the stock route, but i wont be using the stock piping. I will be having some stronger thicker piping made up using mild steel. This will be the same size as the Jap kits which also come back the stock route, and i've noticed that the air box etc isn't used when these kits are.
you sure? its usually the hybrids that dont allow you to use the stock snorkel, and because of that people usually ditch the stock airbox and make a CAI using the hole freed up under the airbox.
So what brands of intercooler allows us to use the stock piping?
Choyda u wish to clarify on that please?
blitz lm
arc kits
there may be others, but those are the 2 i know of.
there's 2 types of kits
Turn Flow = pipe goes through the battery tray
Cross Flow = using stock pipe position
In this pic you can see the R33 and R34 kits go behind/under the cooler to return to the stock piping, and not come up through a hole in the battery tray area and over the fan blades
Hey guys and girls :nyaanyaa:
Sean
here is a pic of mine, with the ugly pipes...... im going to get a greddy plenum to do away with the pipes over the engine...i hate them...
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
