Originally posted by chopobo
Cos originally when i saw this car it had 18" chromies and i told him to change it normal 16" for me when i bought it. Guess he didn't do a very good job at it.
feck i also had a bad dream last night. Dreamt the guy wouldn't do it under warrantee and wouldn't tow my car. Woke up feeling shit. Just called my manager and told him i won't be coming in today.
if he wants to be an ass and not fix it...you have full right to sue him....in fact...he'll be stoopid if he doesnt.
he will loose a lot more if you sue him - negligence on his part, its obviously his fault for not checking the wheels after he changed them
and then you can sue him for emotional damage - i think dreaming about it would proove that
and lost money from not working
and then you could probably get him for wrecklely endangering life/lives
....as bad as it sounds now, id say you have no need to stress, just a pitty about the cruize
  • Replies 64
hrmz i dunno
shouldn't my mechanic guy pay for the towing?
i just want to make it easy
it should hold with 4 studs right?
haha or maybe someone can weld on another screw
well im gonna try
i need to find a good route slow route from reservoir to springvale.
up to you chop but I wouldn't risk it for the price of a tow maybe 100 bucks or a bit cheaper you could get stuck somewhere or somethign worse might happen or worse have an accident.. give jack a call and ask him how much tell him you are from skyliens forum he will help out a fellow owner I got stuck after he left with the skyline yesterday flat battery eh came back helped me get it started and then followed me to the petrol station to make sure was okay,. He / Noontas who is the guy he is driving for do heaps of improts and always look after the cars. He has helped me out of the shit many a time..
Guest INASNT
that suxs dude.
Sounds like the guys who sold u the car put some bodgy nuts on when they changed your rims, coz for the nuts to just come undone like that is farkin weird. U sure u had 5 nuts on that wheel in the first place? Dont drive it back u will *** up more stuff.
i feel for ya chops........at least nobody got hurt. maybe its a good idea to get the original 17" back on with the proper nuts??
anyhoo's......im just going for the meet up on sat cause i got a bday to go to later so u could bum a ride off me to the stockyards and then jump in someone elses car for the drive in. not the same as drivin ur own liner but at least u get to meet everyone:D
dont worry...................be happy.......dooooooo.....do.. do.. do do......do de do de do de dooooo!!:)
well the his mechanic rang me and he reckons someone tried to loosen the nuts and said to bring it down.
thats ****in bullshit, i didn't touch the wheels at all,
well **** he sounds unreluctant to fix it on warrantee, he said he personally did it himself and tightened them
and he told me to tow it
thats bullshit im not paying for towing all the way from reservoir. So i told him to speak to the boss (Van) about it and then ring me later.
this is gh3y
hey ice its in a pretty safe place atm
um, chop...it dont look good:(
i just got back from milk's place....the word dodgy comes to mind with that car in a BIG way...seriously, id be asking for a refund(if thats posible?) also, something doesnt look and sound right with the back left wheel?
tightening the nuts, it felt like the thread was wrong? the nuts are smaller than the wheel brace. just wondering if there is a universal thread size used on all cars or if they're different? or wheather the threads on the bolts just got fcuked up when the wheel was loose?
yea it seems drivable (kinda) but its risky/unstable...i dont know how far you want to drive it
have you made any inquires about price for towing? it wouldnt hurt to know instead of just guessing. as far as i can see...you should have nothing to do with it getting fixed up! it was there fault, wheather that can be prooved tho?
it makes me sooo angry to hear they are trying to shrug you off!
i would be glad to help if you intend to move it tho...not that i can do much:(
ok called jack the tower
he quoted $120
which is ok
[thanks ice180]
my mum is getting a hissy fit and doesn't want me to pay for the towing. she wants me to take the guy up there to look at it himself. *sigh* now shes all angry at me and taking it out on me. farking i don't need this.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
