Well here is my problem...
Plug in the pfc. The hand controller doesnt turn on. Put keys in and turn it to ACC. The hand controller turns on. Turn off the boost controller unit.
Turn the keys to "ON". At this stage the engine light and the exhaust temp sensor flashes repeatedly and I can hear a tapping noise comming from the fuel pump. Fuel pump seems to prime. I wait awhile crank the engine to try and start it and it wont budge!
Plug back the stock ECU and everything works, car starts, just doesnt like the PFC.
All alarms are turned off. (That I know of)
At first I thought it was a faulty PFC, but I tried another PFC and it did the same thing.
S1 RB25DET 5 Speed Manual.
I have no idea what is wrong. Suspecting its a wiring problem? The stock ECU is an old one with some sort of diagnostic knob at the back of it. :
Edit: In case people dont read this was fixed, cause is explined here: http://www.skylinesaustralia.com/forums/in...t&p=2327813
https://www.sau.com.au/forums/topic/125792-how-to-install-a-powerfc/
Ill take the stock ECU out tommorrow and get some pictures.
Hmm had a re-read of paulr33's pfc faq and this might be my problem?
"Some cars only (for some strange reason) have half gauge wiring running from the battery to the ECU. This works fine for the factory computer but the PowerFC needs the full 12volts. You can simply run new 12volt wire from the battery to the ECU and this should correct this. This problem has been experienced by at least two members previously (both in R33 GTST)"?
I am unsure how the 12v feed will affect the PFC, other than "it doesnt work", I know the hand controller runs of a 5v feed. Try this.
FC in and hand controller in
turn to ACC
check out SENSOR SW CHECK under ETC
post up what sensors are in black (backlight) highlited
Hmm ok I have some pics of my "stock" ECU. See below.
This is what I just tried before..
I tried plugging in the PFC again. This time I took note of what happened.
Plugged in the wiring loom.
Plug in hand controller
Disable alarm
Turn the key to ACC. Nothing! Hand controller doesnt turn on! wtf?
Turn the key to ON, Hand controller comes up APEXI Screen then it just freezes at the "RB25DET" screen.
All this is happening whilst the engine light and exhaust temp sensors are flashing and the ticking sound is heard from the fuel tank.
Once again unplug everything and put stock ECU back and everything works fine.
Weird thing at back of ECU:
ECU Mounted:
Hmm after talking to people. Seems like the pic above is a stock ecu and nothing special about it.
This leads me to the wiring. The plug loom u see there is for the AVCR.
Or possibly the pfc isnt recieving enough volts at ACC to start up?
As the stock ECU only needs 8v to start, while the pfc needs the full 12v?
Hmmmmm
The PFC h/c and fuel pump prime should only show/be heard when in the on position, then a further turn to start will have the car start, letting go of the key returns it to the on position where the car continues to run.
Check the sensor sw screen and post up ALL of the values, preferably take a photo of the screen and post it.
joel, from what Victor has told me. it stays on the RB25DET version screen and doesn't continue through that point to the menu's. he was able to get in there ONCE while at hitmans to turn off the boost control.
he told me also that the AVCR doesn't have any values for INJ/TPS etc coming to it.
also what i found was strange, he said it doesn't Crank over when turning the key to start.
ahh no problems...
When my pfc was in for repairs it would hang on the intro screen when it wasn't receiving certian inputs. i.e simply running power through it. Once installed it was fine.
Its also been known for the plug to be slightly off and not done up straight causing it too to hang on the intro screen.
But yes if the avcr isn't receiving values either then something is definitely up. :unsure:
I would check removing the ecu hasn't broken/distrubed the work done on the loom when the avcr was isntalled.
should have elaborated a little..
the AVCR works fine when using the std ECU, but not at all when using the power FC.
edit - did yours crank over and just not start when your PFC fried ?
Edited by Craved
Havent checked fuses.. But with the std ECU works fine.
It may be the PFC simply not recieving enough volts. or wiring missmatch, though I cant see why.
Ill try jump starting it via jumper leads tommorow. Unless its bad to do this. :
It all too confusing right now..
jump starting it is, but if wont go past the rb25det version display then theres no point. the FC is locking up for some reason.
turn the car off.
hold up on the hand controller
turn it on.
what comes up?
d00dz I wouldnt be experimenting to much especialy with straight power ! I know nothing about this but hard wire jumping the car or Ecu cant be good ... get it tested or give it A fresh 12 volts but lighty fused...
Get it tested Professionaly so you know
You dont want to blow any Warrenties because your frustrated !
jump starting a car with a PFC is no different to stock ecu.
ive done it before twice and it works just as normal (as its supposed to).
it sounds like you have the wierd wiring (not 12v guage) at a guess
Hi Guys
had exactly the same prob the little blue relay next to the battery in the boot ticks like mad. iafter ripping half the dash apart and checking all the voltages from the pinouts it was just the fuse the fuse box has two rows top to bottom its the left hand row sixthfuse up runs fine on old ecu -nothing but start screen on PFC
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
