post-3774-1153023845.jpgIN ADELAIDE
im selling my Kaaz 2way diff. I had the run in oil changed to kaaz oil about 5000ish km ago.
$850 ono. Its 5 stud on the halfshafts that connect to the driveshafts and 4stud connecting to tailshaft.
Transport MAY be possible for free to a local booths depot.
Edited by HRthirtyone
https://www.sau.com.au/forums/topic/125857-kaaz-2way-diff-r32-850/
hey mate im pretty keen on a new diff at the moment, if you can pm me ur datails maybe we can work
something out!
do you know if its possible to change the 2 way to 1.5?
Edited by DriftR_33
Willing to send interstate?
What would it cost to get the diff to 2324 NSW?
I was quoted $80 to get a diff from Brisbane to me so i would imagine it'd be similar.
Jarich
who would i use to send it? postal services only do up to 20kg, and couriers dont do private stuff do they?
Some couriers do private, i think it's only big ones like Toll Ipec etc that only do companies.
I've not actually sent anything myself via courier but i've had things up to the size of an entire LSD cradle with diff axles and hubs sent to me via courier, the entire IRS from QLD to me was like $150 i think.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
