pics? neg on price... will they bolt up to a 180 no probs...
They wont 'bolt' in, one of the holes/mounting points requires modifcation from memory when fitted to an S13.
Pair of front seats out of a 93 r32 gtr,no signs of wear in the bolsters or the material,these are the best ones i've ever seen apart from one minor (repairable) cigarette burn.Perfect upgrade for GTS-T as they bolt straight in and need no modification or modification approval.. only $600
Ben 0411344824
Can i please see the pics
Pics now added.. please note that seats look dirty in the photos but they are not.. pics were taken in a garage with no light and the flash makes them look that way!
hey do these have the same rails as 33's and are there any difference between the 32 gtr seats and the 33 gtr
rails are the same in r32/r33..i think they only slightly changed the trim on the seats in the series 3 r33 gtr but are the same seat in both cars(r32 and r33 GTR).. couldn't be that hard to modify the seats to go into an r31 as i think they're pretty similar to a31 cefiro and have seen that done plenty of times
hey i'll make the first offer of $400 for both. if i was going to spend $600 i'd rather get two immaitation leather recaros with rails. you'll probably want to wait to see if you get further interest but atleast u know my offer stands
thanks for the offer but no thanks.. and good luck in a machinery inspection when they cant find the adr tags on the seat to say they suit australian standards.. i've had enough trouble with genuine brides and they aren't known to snap in a collision..
I woulda bought them if they were in sydney.
speedfreak says "you gotta consider that". Gtr seats normally go for 800-1k.
You shoulda bought em :wave:
Ben got me a awesome deal on shipping!
Shipped yesterday and arrived today!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
