Armourall extreme tyre shine. It doesnt stick on the tyre properly, consequensly it flies off the tyre and will go around the guards and when you wash the car the paintwork will go all specaly. My cars black so it wasnt too bad, but its damaged the paintwork (cut and polish should fix it) but it shouldnt have happened in the first place.
https://www.sau.com.au/forums/topic/12604-avoid-this-product/
90% of tyre shines are silicone based and hence why it looks to make your paint go silly........ what u should try and do is use whatever tyre shine you use (armourall etc) and put it on and when it starts to disapear wipe as much as you can off with a soft rag...... and note: if you "spray" it of from too far away it will get on your paint anyway so do it close and take it easy......another thing i can tell you is that here at repco or atuobarn you can buy a spray can of tyre shine with a black tin with white writing and a BLUE lid...its really cheap and it doesnt flick off and its very effective but it only lasts a day or two...its like $2 a can.... i hope this may help you in some way shape of form..... i am a car detailer by trade so if you have any more questions feel free to ask me........Jon
I use the maguiars tyre stuff and then windex to clean anything on the car afterwards... works miracles...
altho my car hasn't been washed in the last 4 or 5 months lol
johnson's baby prodcts are mad... they're so mild yet soooo effective
yukoff
just spray it on dont usually have to even wipe it off gives a nice finish
i even use it on the colt, the wheels are black so i spray them they look new, i spray the tyres, beautiful, i spray the bumpers the colt turns imaculate :)
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
