The funny thing is that I hadn't polished it at that stage ;)
Now she's polished again, we should try and get together with a couple of those who missed out on the last night shoot.
Is after we meet at the museum this Friday okay?
Jeno? You're another who missed out... anyone else?
i know exactly who you are talking about and i intend on getting their tyres at some stage.
at the moment my budget can probably buy me 1 tyre.
i will try and find some second hand ones somewhere
Blueprint
R33Driftr
RB20tR32
CeJay
Tourismo?
Steddy?
Will only have enough time in the evening to take a couple more... because Mark would like to spend more time on these ones. I think he wants to do one with the owner beside the car as well.
If the venue is taken up, we will soon find something else interesting to use as a background.
I wouldn't mind a couple of nice pics actually, for when I sell her...
if there's time to do it, I might come along too?
Blueprint
R33Driftr
RB20tR32
CeJay
unSteddy
micky_tee
Shell
I think we should meet at the museum a little earlier if thats okay with everyone say 8:30 - 9pm as it can take a bit of time.
There is a function on friday night at the museum, so it will be packed and the po po will be everywhere, so i reckon it might be worth meeting somewhere else. I might pop out for a short time, but i got heaps to do on friday, so no promises.
okay how about meeting at the same place we met for Marques? I thought there was a good photo background under that bridge anyway, we could start shooting straight away then.
For those who didn't meet at Marques, Cejay put a good map up in the Marques thread.
We did a photoshoot for Bullet32 and Frink's cars under the bridge about a year ago, it works pretty well.
Some of the lights under the bridge don't work but that's nothing that can't be fixed with a bit of good old fashioned photoshopping :)
If youre in the market for tyres, Im happy to help out. :)
PM me for pricing...
I know this great brand. The name starts with the letter F and ends with the letter L. Use them on both my cars and they are very nice :) (end of advertising)
How was that Mick? You like it? I have more.......
Well done Jeno... Youre such an ambassador for the brand...
P.S. Your cheque is in the mail :(
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
