hahaha yes reece wtf :banana:
good night, but yeah was bloody cold. I'm just lucky I remembered to bring my good ol' SAU jacket! (haha thanks again shell)
good drive home too lol I quite like those roundabouts heading back towards civic at that hour with no traffic....pity canberra roads are really starting to shit me with how unpredictable the rough bumpy spots are ;)
yeah I was trying to find a way to signal to you "hey lets f**kin' plant that shit in the tunnel eh?"
I think we were both on the same channel tho, it was hardly necessary :banana: we're cool like that!
haha I had a bad experience in that tunnel ...
on the inside far right lane gave it a hit then coming out of the tunnel i noticed a guy had lost his queensize matress off the back of his trailer and it was right in the middle of the lane coming out of the tunnel with glare in the face and then seeing it and hooking to the left sharply then trying to get it back inline quickly resolting in cutting off the car in the lane over when the rear end kicked out sideways @ 90kph infront of him ... not a fun experience @ all quite scary
I might come out n say hello ... depends if I stay back at work and pull the motor out of my other car tommorow night or saterday morning
Doing a Jap spec 1600cc Twin cam turbo engine conversion on my laser TX3 (Jap B6t ) should be the goods
Suppose so, as long as there's ppl keen :P
My number is on the previous page, if anyone's heading out but hasn't posted up on here, msg me. otherwise I'm gonna swing by at 10 and hang around for 15 mins til someone turns up, if no1 is there yet.
Me and VeilsideR33 drove past after dinner but no one was there...
oh and I know this is a long shot but I'm trying to scab a lift from southside to dickson tomorrow night :( If anyone is going that way lemme know!! I'll give you petrol monies!! ;)
Depending on how my wiring goes this week
I might come out in my TX3 for a change ... with the new Turbo engine in it and running (Pending some minor Engine loom to dash loom wiring issues at the moment)
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
