You want to get rid of body roll, dont go looking for getting coilovers. These coilovers with high spring rates as give u nothing but the shittest ride around. If you want to get rid of body roll, go for upgrading your sway bars.
I highly recommend SydneyKid's group buy for Bilstein Shocks, Whiteline accesories, or at least speak to him bout it.
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2331128
Well I got a price of $2500 supplied and fitted, alined etc for the 'aussie' spec teins from Fulcrum. That was the works in terms of the suspension gear its self, no camber or castor kits.
SKs set up came in a fair bit cheaper. In my case anyway. That and I feel I have a better quality product.
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2331748
lookng 4 options any sugestionsn allredy have sway bars etc'
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2331844
I did too. So sway bars werent included in that price. I wanted a proper fix as I had rebuilt jap coilovers to aussie road spec, and 3 of those failed. I didnt really want to replace the stuff again.
So after my own research and a long conversation (and a few shorter ones :P ) with SK I decided that for what I wanted the bilstiens were the best and most cost effective (not cheapest, but the service life would seem longer than jap coilovers) option. Reason for getting them through SK over anyone else is he is and will be the cheapest, unless you get lucky and find someone who has ordered the wrong shocks and is trying to flog them off cheap.
Id talk to SK, read the shock 101 thats sticked in this forum, ring say fulcrum and talk to them (they are a tein dealer and do have a 2 year warrenty or something). Then make your own then educated decision on which way to go.
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2331977
Well my Bilsteians after about 5 or 6 years of faithful service are coming out. Last inpection about 24 months ago had them in perfect health.
I cant makeup my mind on another shock, they are all too much money to find im not happy with the buy, so in the next 4-6 weeks they will be coming out and be stripped down and rebuilt.
New higher rate springs and converted to fully height adjustable. Will report back on what the shock condition was before rebuild, im guessing they will are fine...
Still works out cheaper then even the basic bottom of the range adjustable coil overs available on the market.
Though if someone wants to save me the agro and sell me their new still in box HKS Hyper Max II for cheap then i will buy them ;)
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2332060
Base adjustment? I take it as meaning that you can adjust the ride height of the car with an adjustable lwoer spring seat, the threaded bit.
At the end of the days, its all a matter of personal preference and what you do with your car. Some swear bv a certain brand, others dont care. Im more the dont care what brand it is...im just sensitive to the fact that overall im pretty happy with the Whiteline kit i h ave and dont want to spend thousands on something that wont make me go any quicker over 1 lap at the track...plus i seriously doubt that i would be able to actually go quicker because of better suspension.
Odds are what feels quicker to me is slower ;) So, thats me. You need to think about what you want from your car and what expense you are willing to pay.
The fact that your looking for a really good price on Teins suggests that you are motivated by budget like me, so best advice is go for a drive in a few other GTSts and see what you like the feel of.
If you just want a nicer handling car with good ride, then you cannot go past Whiteline Swaybars witha good alignment. Thats about the only thing i know for sure :D
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2332343
budget important but no be all end all
as always u dont want to pay too much for something when u can get it cheeper
i dont want to be looking at new suspension again 4 a long time so i want to get it right got a few mates with tein flex in there car and they sware by it so realy need to find some people in qld with some setups to compare
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2332505
ive had the tein h/a's for almost 4 years, they are firm ( roughly middle setting, so they can go alot harder or softer) some ppl find them too hard, some dont mind, im personally used to it, and i prefer hard suspension it makes me feel more in control of the car, i get 0 bodyroll and i have stock sway bars etc, just comes down to what u like, the flex or super street might be a better option which would have gotten but they werent out when i got mine and a bonus u can have the edfc hooked up to them as well, as with the H/A's u cant
ben...
https://www.sau.com.au/forums/topic/126129-tein/#findComment-2351405
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
