s1 r33 gtr inspired front bar (modified to suit fmic) - SOLD
condition: repairable crack (quoted $50 from jetspeed to fix)
s1 r33 veilside sideskirts - SOLD
condition: they were on my car, theyve got some damage on them but are easily repairable
cheers.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
