Hey guys installed a amp and 2 subs on my car and was wondering what guage wire you should use from the sub to the amp?
I just cut up some RCA Wires and hooked it up with them but the subs sound like shit. There not loud at all and sound very distorted, they havnt got the puch of a sub. Any Help would be good.
I have a mono block amp with 3000 watts
and 2 12' 1000 watt subs hooked up to it.
https://www.sau.com.au/forums/topic/126288-amp-and-sub-install/
I have 4 6" speakers and a pioneer head unit.
I have hooked up the amp and sub it sounds awsome but when i turn the key off I get a loud pop from the sub.
Anyone know what this is caused by.
you need this:
that will ensure everyting is working properly.
give us a rundown on what else is in the chain.
Your turn off pop could be caused by a lot of things, the main offender is a cheap chinese amp with inferior circuits.
but.....
As your amp is running 3000w rms (claimed) to 2 x 1000w (claimed subs) a prefab box and power kit off the shelf will be no good at all.
You need
Thick Cable.
0-1 guage for power and earth
0-1 guage for earth from battery to chasis and upgrade of alternator wiring
4-8 guage for speaker wiring
10 guage for remote amp tunr on
and rca's would need to be something good, stinger, etc. (dont buy the cheap ones)
If they are 1000w (claimed) subs you will also need to make a fibreglass reinforced mdf enclosure for them. No point spending all these $$ on the good stuff and putting them in a crappy box.
Boxes that have fibreglass reinforced mdf are always custom made. Which is the ideal enviroment for a sub or two anyway.
I would budget $800 on the wiring and another $500-$1000 for the box ( depending on the quality and design)
There is a stack of other stuff, lines drivers etc.
But i'm guessing by now your a little scared by this. So here's what you do.
Quote the rms figures not the peak power figures.
Quote the distance from battery to amp in cm's
Quote the type of enclosure the woofers will be in (needed to establish power handling requirements)
Tell us a little about the bass response you are after
And finally, model numbers of the equipment.
Then...
Well then i can give you a little less scarey answer.
scary alright.
Subs sound good man but just the loud pop when turning it off. It does not do it when you turn it on but.
but.....
You need
Thick Cable.
Then...
When you say upgrade the alternator wiring, could you elaborate a bit more?
What i mean is to have thicker cable between the alternator and the battery so that more current is allowed to pass to the battery and help to charge the car more efficiently.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
