It's On! Lakeside - Better Late Than Never
Okay everyone, Monday the 24th is good to go (next mon)
Two sessions: 8:30am to 12:30pm, and 1pm to 5pm
Cost is only $100 per person per session (you can stay for both if you want, there may be a discount depending on how full the sessions are) and there is a limit of 20 people per group.
Cars don't have to be registered but will be scrutineered for very basic things like tyre wear, battery secured, no oil and fluid leaks....that's about it. There aren't any noise restrictions as such, but use your better judgement as to what will constitute 'too much noise' as you will be given a warning and chance to remedy the situation or be kicked off the track. Put simply, open pipes would = no good.
Expressions of interest here first, then by wednesday I will give booking and payment details.
Who's up for some fun?
Link to original thread here:
http://www.performanceforums.com/forums/sh....php?t=67205233
note: i am not organising this, someone else is, but i thought i'd share the information with you guys
it went okay... was a bit annoyed at some of the goings-on and the way things were organised, but it all sorted itself out in the end, so not too bad i guess....
i have decided i need more power, and better rubber
and stiffer springs
You gotta say that getting onto that track was worth the f*ck around? They obviously weren't expecting the turn-out they got for the sprints section, but they still shoulda paid more attention to ya Jason. Good to put a face to the name mate.
Cheers. :)
yeah, i managed to get 3 sessions in a row at the end, so that made up for missing out on the rest of the day i guess...
and yes, it was worth getting out on the track...
i'm glad i didn't spit the dummy and tear into them and demand my money back now :)
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
