G'day guys.
These are from Import Car Parts Plus in the USA.
GB: START 18/07/06 ENDS 10TH/08/06
Im in need of some cam gears and so are 2 mates. These things are so dam expensive for the Jap brands.
What i found was some Arospeed USA RB20/25/26 Cam Gears.
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
These camgears are good for a RB20, RB25, RB26.
To keep the price down, I need to order 10 sets thats 20pcs in total. (Come only in Blue Colour)
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you. Both ways are fully tracked so they won't go missing.
Express post cost an extra $10 nation wide.
Cost Price of the cam gears is $170 for the pair, or $85 for 1 pc.
So total cost for a pair will be $170 + $10 postage = $180
This gb will end in about a month or before if we can get the numbers.
Ordering To order a pair, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ $140
Lets hit the 20+ and save!!!!!!
Come on SAU members, im sure we all need camgears and if we can get them for $70 each gear that will be a huge saving.
These are made out of the following material and only come in blue.
RACING ADJUSTABLE CAM GEAR : al7075 forged billet
This is the list we have currently.
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
10)Tangles *IN
11)Kozeyekan *IN
12)NICKS33 *IN
13)stolen *IN
Edited by r33kid
https://www.sau.com.au/forums/topic/126510-arospeed-adjustable-cam-gears-pair/
  • Replies 219
I'm keen for a pair. And i'd like to see some bigger photos aswell, i couldnt find any details of RB camgears on www.arospeed.com
Some Info i was given from the supplier in the US.
Arospeed announces that it has created a five-bolt design for easy Tru-Time Adjustment.
Arospeed cam gears with an updated design.
Arospeed Adjustable Cam Gears are used by top racing teams across the USA and are a must for engines that are forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in two-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and hard anodizing on the gear teeth is lab-test-proven to be the hardest anodizing process on the market
Key Features:
Increase horsepower and torque without any cam changes, and are ideal for heavily modified engines
CNC-machined from AL7075 billet aluminum
True laser-etched markings on the leading edge of the gear allow for quick, accurate adjustments
Hard anodizing on belt surface is the most durable anodizing on the market
Grade-8, six-point hex bolts stand up to repeated adjustments and feature integral washer flange for greater load distribution
Hope this will answer all your questions.
Edited by r33kid
I'll have to re-check my finances when you do the order, but tentatively put me down for a pair (for RB26, don't think there's a difference?) It doesn't matter what the final cost is, I'm willing to pay the full $180 as long as I can afford it at the time. Thanks!
I could be keen for exhaust cam gear for r33.. So only need one..
When does the group buy end??
Also where are you located??
pickup ok??
Edited by siddr20
pickup ok??
Im located in Sydney, pick up is ok but im quite busy with work, typing this now from work, so its easy for me to express post
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
We need more ppl so pass the word around.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
