G'day guys.
These are from Import Car Parts Plus in the USA.
GB: START 18/07/06 ENDS 10TH/08/06
Im in need of some cam gears and so are 2 mates. These things are so dam expensive for the Jap brands.
What i found was some Arospeed USA RB20/25/26 Cam Gears.
Here's all the info on them - make sure you read all of this cause it'll probably answer all your questions.
These camgears are good for a RB20, RB25, RB26.
To keep the price down, I need to order 10 sets thats 20pcs in total. (Come only in Blue Colour)
How to get onto this great deal"
You can do direct deposit into my account then I'll express post them to you. Both ways are fully tracked so they won't go missing.
Express post cost an extra $10 nation wide.
Cost Price of the cam gears is $170 for the pair, or $85 for 1 pc.
So total cost for a pair will be $170 + $10 postage = $180
This gb will end in about a month or before if we can get the numbers.
Ordering To order a pair, just put a post up here or you can PM or send me an email at [email protected] with your details.
Feel free to ask me any questions.
Also this is a price break i was given if more than 10 pairs are ordered.
10 - 15 pairs $160
15 - 20 pairs $150
20+ $140
Lets hit the 20+ and save!!!!!!
Come on SAU members, im sure we all need camgears and if we can get them for $70 each gear that will be a huge saving.
These are made out of the following material and only come in blue.
RACING ADJUSTABLE CAM GEAR : al7075 forged billet
This is the list we have currently.
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
8) 180 mph *IN
9) Jaqule *KEEN
10)Tangles *IN
11)Kozeyekan *IN
12)NICKS33 *IN
13)stolen *IN
Edited by r33kid
https://www.sau.com.au/forums/topic/126510-arospeed-adjustable-cam-gears-pair/
  • Replies 219
I'm keen for a pair. And i'd like to see some bigger photos aswell, i couldnt find any details of RB camgears on www.arospeed.com
Some Info i was given from the supplier in the US.
Arospeed announces that it has created a five-bolt design for easy Tru-Time Adjustment.
Arospeed cam gears with an updated design.
Arospeed Adjustable Cam Gears are used by top racing teams across the USA and are a must for engines that are forced induction, high compression and/or utilizing aftermarket competition cams. Our gears enable users to match cam timing with their vehicle's tuning state by advancing or retarding the cam profile in two-degree increments via true laser-etched markings. Precision-cut gear teeth ensure no premature wearing of the belt surface and hard anodizing on the gear teeth is lab-test-proven to be the hardest anodizing process on the market
Key Features:
Increase horsepower and torque without any cam changes, and are ideal for heavily modified engines
CNC-machined from AL7075 billet aluminum
True laser-etched markings on the leading edge of the gear allow for quick, accurate adjustments
Hard anodizing on belt surface is the most durable anodizing on the market
Grade-8, six-point hex bolts stand up to repeated adjustments and feature integral washer flange for greater load distribution
Hope this will answer all your questions.
Edited by r33kid
I'll have to re-check my finances when you do the order, but tentatively put me down for a pair (for RB26, don't think there's a difference?) It doesn't matter what the final cost is, I'm willing to pay the full $180 as long as I can afford it at the time. Thanks!
I could be keen for exhaust cam gear for r33.. So only need one..
When does the group buy end??
Also where are you located??
pickup ok??
Edited by siddr20
pickup ok??
Im located in Sydney, pick up is ok but im quite busy with work, typing this now from work, so its easy for me to express post
1) R33KID *IN
2) 2GU UP *IN
3) R33 STAGEA *IN
4) xRHETTx *KEEN
5) AWDMAT *KEEN
6) JIMx *KEEN
7) Siddr20 *KEEN
We need more ppl so pass the word around.
