  • Replies 219
hey r33-kid
giffo here!
still havent heard back from you, i have sent u numerous pm's and no reply! what the hell is going on here buddy?
yes i have paid...
and u say that they u have started to send them out!
where is my phone call mate?
i would appreciate some feedback and communication! sorry i had to post up here, but you havent written back to my pm's!!
call me... you have my number in a pm!!
thanks
Garth
Maybe u can organise anyone that wants to pick up, to meet in 1 place at 1 time, so theoretically should only be as long as passing out and checking 10? orders.
Shouldn't take too long.
Just an idea :)
should we be expecting the cam gear this week or next week
just i know when to check the post office
Any info would be good, just cant wait to whack it on and get organise for my tune for my other gear
hey r33-kid
giffo here!
yes i have paid...
thanks
Garth
Sorry Garth
Work has gotton the better of me, ill call you this week.
People i have posted some out and posting more out this week, like i said just be patient, you will all have them by early next week.
lol how do i give trader feedback??
Edit: sweet figured it out..
Cheers!!
ps. For those who install it sometime soon let me know how it goes..
Anyone doing this by themselves??
Edited by siddr20
Cheers!!
I will be, as soon as i get them, from memory i think i will be able to do it without removing harmonic balancer or radiator, as long as i can get to the adjusting bolt for the tensioner.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
