Posted: Mon Jul 17, 2006 2:28 am Post subject: :FS: r32 gtst 4dr (drift ready) w/ pics
my skyline for sale or trade,
wanting to trade for something thats good on fuel economy...
maybe a s13 or something....
or im asking $12 000 ono.....
89 r32 gtst 4 door
dark blue
rb20det
full 3 inch exhaust, turbo back
air filter
front and rear struts
tein hr coilovers
GTR rims
2 WAY LSD
big front mount (delta fin style)
blitz bov
gtr front seats
nismo gear knob
razo pedals
nardi steering wheel
omori boost guage
drift button on park brake
pioneer cd player
km 5X XXX... i dont think this is true for the cars age...
in the pics the wheels are sparcos which ill also throw in...
along with some other parts not installed like various guages, stock suspension, boost controller.....
pic 2
Edited by r32-
https://www.sau.com.au/forums/topic/126535-fs-or-trade-r32-gtst-4d/
yo just realised ur a local i recognised the carwash :D
vic road... near ryde!
gud luck with sale im selling my 2002 yamaha R6 and 84 323i bm to get a 32... fingers crossed it happens soon.. if it does ill give ya a shout...
BTW what are the pros to owning 4 door 32?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
