Hey,
Got first service since owning a r33. I dont know what oil the previous owner had in it but my mechanic (who is my dads mate) put Mobil XHP 15w-40 in it. Before having this service my oil pressure guage was mainly around the 4 mark. When cold & warm. Now since the oil change the needle is all over the joint. First thing in the morning the needle jumps right up to the bar between 4 and 8 and then after about 5 mins of driving comes down to the 4 mark, also if i drive for prolonged periods now (25 mins+) the stupid bar drops way down to the mark between 4 and 0.
Is this oil rat shiz?
Am I doing any dmg with this crap in my sump? What are regular needle readings for cold and warm?
Cheers
Mako
https://www.sau.com.au/forums/topic/126592-standard-oil-pressure/
this happened to me aswell and i am using motul 4100 full synthetic
My mate uses a MOTUL oil, i think it is called TurboCharge Light or something like that, not sure of its temp ratings but he reckons it is good shiz... but im not sure what his guage displays, i will have to ask him...
how long have you been using that oil for and has this only just started happening to you to?
When cold - oil pressure should be around 6..
When warm - @ 4,000 rpm should be around 4..
When warm - idle - should be around 2..
- Colder the oil.. the higher the oil pressure.. the harder you push the car.. the higher the oil pressure.. normal cruising - you should sit around 4 unless you come to an idle..
Oil pressure should vary.. it's normal.. if you don't know why - I suggest you read some sites on the web regarding cars or oil pressure
Edited by Links
ok kool thanx for the feedback guys, it is possible that it was doing it before i changed oils but didnt notice but im not totally sure, anyway i feel more comfortable now knowing it is normal as it does make sense i just didnt expect it to vary from 2 to 6. I will conduct more research on oil pressure and temp just for personal interest.
Thanks a lot everyone
mine does exactly this.. i think it's just below 6 at idle and when i'm doing ~2500rpm it is just above 6. but the other readings are spot on.
yeah. mine when warming up is around4-6 when warm. it idles 2-4 when on highway just below 4 but come off the highway and idle its below the 2 line. but drive again and its fine. stop and idle again and it will either be 2 or below 3. ive had it once halfway between 0-2 bar. this is on my 32GTR. im told the guage is shit and has a shitty reaction. dnt go by it and only go by the redlight on ur cluster if the light is on off goes ur engine..
Lol.... Yeah hopefully i'll never have to read that light.
Mine is all over the place aswell. It start off at about 6 for a bit then drops to 4 then after a while goes in between 0 and 2 and then goes back up to 4 and then back down to almost 0. It's really annoying because i got no idea what it's really at. looks like another guage is the way to go.
Its happened to me right after my oil change as well (motul 8100 5w40) or maybe i just didnt notice it before.
Around 6 when cold, slowly goes down to 4, then when the car gets warm goes to about 2, then after that just flutters around 2~4. This is in an R34 Gt-T btw.
  • 4 weeks later...
Guys,
I've got an R33. I've just rebuilt the engine and it drives great but I had the same problem with my oil pressure guage all over the place but it wasn't the gauge, it's the oil pressure sender under the bonnet near your oil filter.. get that changed... it only cost me 50 for the replacement part from another car... cheap fix.
in addition to the above, can anyone help me out regarding the method of changing the sender on an R33?
I have the sender and can see where the plug goes into it, just need to know how to go about changing it or whether it is best left to a mechanic. don't want oil to be spilling out all over the place if i remove it.
this is a requirement of a RWC and i kinda need this sorted this afternoon!
any help hugely appreciated.
Edited by thommo
Your oil pressure should fluctuate, it's not going to stay @ the one level constantly, as you rev the engine higher and the oil warms ujp the pressure will either build up or decrease...
As long as it doens't drop below 2 too often, and doesn't go over 7ish.. you should be fine..
If the oil pressure light comes on, your in serious trouble, so either get an aftermarket gauge, or just check to see if yours is working..
Makes sense what those have been saying about the fluctuation of the gauge. Mine does exactly that. Starting off slightly higher then dropping slightly to around 4 when warmed up and cruising and down to 2-3 when at idle. I'm using Motul Turbolight 4100 as many others are. Considering for normal suburban driving this fluctuation is normal and fine, in fact it would probably be more of a problem if this wasn't the case!
Also keep in mind other cars don't have oil pressure gauges so while oil pressure is important, especially for a turbocharged car, it isn't the be all and end all. Hell, my bf's car didn't even come with a tacho!
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
