hey all,
i am looking for about 250rwkw on my rb25
i curently have an Apexi AX53b 70 turbo with stainless lowmount manifild full custom exhaust an HKS pod
what other mods am i gonna have to invest in..??
i would like not 2 have to crack the engine open at all if posible
proposed mods: Power fc, apexi v-spl cooler, new injectors new fuel pump
also want 2 keep it as lag free as posible
thanx all help appreciated,
Glen
Edited by R33_KRAZY
https://www.sau.com.au/forums/topic/126664-looking-for-250rwkw/
Your spot on mate, only thing "maybe" cams if your budget allows, if it does not, dont worry as they are not essential.
Everything you've listed on the "to be done list" is exactly what i would say... Just make sure the fuel pump is getting the right voltage and you should have a good setup
i currently have 228rwkw also chasing 250rwkw
i have
power fc
hiflow plain bearing turbo
walbro fuel pump
ces split front/dump pipe
FMIC
AVCR ( Set on 12 psi )
Hiflow cat
3"exhaust
I am soon to have installed a Z32 AFM , nismo fuel reg, and 555cc injectors, and goin to bump it up to 18psi
We are led to believe, might be able to crack 260rwkw safely
And as for lag, mine has hardly any at all, even though its plain bearing and does produce more heat, and more time to spool, Too small of a turbo to notice .
Im in the same situation as for not wanting to open up the engine, as this will be my last of mods, b4 i would have to look at doing this, if i want my engine to last.
how much power is it safe 2 make with an rb25 and how long will it last for being a daily driver.. happy 2 peg it at more like 200kw fro daily drives but want more when teaching ricers leasons
250rwkw is pretty much the limit ( as i have heard) on a stock engine
making sure you do oil changes, and keep up maintenance.
200 rwkw is pretty safe to drive around on, aslong ya not flogging the crap out of it every second,
I have been on 228rwkw, every now and then give it ago, for about 5 months or so, havin the injectors and afm on its limit.
I really should get the 555cc injectors in and afm changed, but still saving, and spending money on piss and fuel.
And i ran 230rwkw and mine died... who gets what is really irrelevant.
Hell i've seen a stock RB26 bottom end thrash out over 500rwkw.
It died in the end, as with everything
Anyway, 250rwkw is a good target and a good limit.
Much more than that on the street is pretty much pointless anyway without spending mega $$$ on tyres and suspension etc etc.
Ive seen just under 400rwhp last (and still going) on a standard rb25 for quiet sometime! If the tune is right and you treat it properly your target is no problems for the motor, wether or not your turbo will do it you'll have to find out!
As mentioned regular oil changes keep your motor happy hehe
hey all,
Glen
easy
my r31 runs rb25
got it back yesturday from tune
microtech
gcg hi flow
fmic
3 inch exhaust
standard injectors
walbro pump
fuel reg
216 rwkw on 10 psi
240 rwkw on 16 psi
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
