sorry to tease everyone but yesterday i saw the sexiest stagea ive ever seen in japan. i managed to get one photo and one video however the pic is a little blurry because my hand was shaking with orgasmic delight. as soon as i get my mini-sd card reader back, ill get the stuff off my phone and post it here!!!!! promise you wont be disappointed!!!
drew.
Edited by imaspy
https://www.sau.com.au/forums/topic/126693-the-best-series-2-ive-ever-seen/
ok got my card reader back. now i know this is only crappy phone quality video and picture. so it cant really do this car justice. i am not joking, this thing looked like it had just been rolled out of a showroom. and yes, that is the glow of neons you can see underneath the car. i dunno about the wing/spoiler, but f**k me it sounded like a million dollars. interesting choice of wheels too, i think they looked good.
drew.
here is a link to the video. sorry bout the quality but photobucket automatically resizes it :angry:
http://s82.photobucket.com/albums/j275/big...rent=MOL003.flv
nicest ive seen is the widebody with 34 front end... wasnt everyones cup of tea but damn as far as wagons go... prolly dont get much tougher.
would LOVE a swat sticker for teh stag....
ps glad i dont live in japan and drive a stag - so many around. like bloody commos over there. boy doesnt the aussie market get the short end of the stick...
hey!!!! the guy that owns the stagie must have just changed the grill... cos on monday when i saw it, it had a sexy, broad-spaced chrome mesh in there.... it wasnt loud and looked great IMO....
hehe yeah and about the video.... notice when i start walking down the street, the girl in front hits a tree with her umbrella... then of course i walk right under it and have my own personal little shower.. lol ... after the finished the vid, she called out 'sorry!' in english to me, it was so cute! :wave:
Edited by imaspy
youd never know. i figure if you can afford to spend that much on a stagea, you may as well do it properly without cutting corners. I think its a gnarly looking beast.
Id love to see a legnum look that tough.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
