Yeah I was thinking of putting it there in the corner of the windscreen, but I just didnt like it over there, so just ran a tiny bit more tubing and wiring and whacked it on the steering column and prefeered it there so left it there.
Mine doesnt have a cup or anything, just the boost guage with a single bit of normal sticky tape holding it down :) very proffessional look :P
I'll go get a gauge holder for it, one day..... :(
  • Replies 47
Where have ppl picked up boost from on inlet man.? I was thinking of picking up from brake booster vac line.
(what he said) :(
There is an unused nipple on the back of the inlet plenum, it has a cover on it, series 1 anyway.
Edited by munchdesign
heres mine.. good old double sided tape from manufacturer
id rather ti be easy to pinch that have everything ripped apart
I like this thinking, but I don't like the idea of it flying off and hitting me in the head in an accident. A 2 5/8" mechanical gauge would be a pretty serious weapon... Ouch!
Cheers
Luke
Tried to mount my boost gadge on the dash 2day with double sided tape and it wouldn't stay. So I sat it cup holder until I get time to make alu. bracket mounting from hand brake release. I really only hooked it up 4 tuning and to see what boost we r running after full 3" ex., K+N panel filter. I have got an R32gtst w/gate act. I am going to fit, so we will see if they hold 10psi then tune SAF-C. I will take gadge out once tuned. Go the Stagea!!!
  • 4 months later...
Hijack alert... :thumbsup: I have started making some gauge pods for the Stagea which should be ready in early-mid Jan. Single pod and double pod to replace the clock and single pod at the base of the A-pillar. See THREAD HERE for more info.
i like the triple din cluster - are they the drift guages in the $175 kit...? can remember who theat was through.... looks good though.
Im lookin forward to mearcats guage holders, for where the clock sits.
I like it too, it's a shame you can't choose which guages you get when you order a Defi DIN-guage cluster, it would make it so much easier!
Not sure if those ones in that shot are the same ones, but Just Jap are doing AutoGuage packages as a group buy for that price...
:P The ones in Logans car are "drift" brand. Same diff, really, with the blacked out faces when turned off. I recently put three into a mates Exa -
They are a good looking guage, but im not sure of the accuracy on the Drift ones. I had a boost guage in my car for a lil bit, made some funny noises lol
you can't expect three gauges for $175 to be accurate... you'll pay easily more than that for one name brand gauge most of the time.
for example,I recently picked up three defi bf's to put into my stagea. water temp,oil temp, oil pressure and a controller II unit for $650.
will look good in the clock and pillar positions I expect.
Justin...
Justin...
Exactly, that's why I'd prefer to wait, save up, and get full electronic guages too. I love the Defi's, just wish I could afford them sooner (as well as all the other mods I wanna do). :P:laugh:
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
