The 34 NEO turbo is almost the same as a series 2 r33 turbo right (in that it has a lighter compressor wheel than the series 1)
And will adapt straight on to where my old one was, in the same way the 33 turboes would?
Will my rb20 wastegate actuator still fit? Im assuming i wont need to run any extra lines for oil or anything.
Thanks, i just read some weird article in autosalon the other day (article on the RB series (clearly autosalon is the epitome of everything intelligent :angry:)) and it seemed to imply a different set up on the NEO's (as well as shorter life, but they probably just tripping there)
https://www.sau.com.au/forums/topic/126777-r34-neo-turbo-just-double-checking/
Nope... search would tell you the rear housing is larger on the NEO RB25 turbo.
There is also a thread with pics in it :wave:
Hmm slightly larger rear housing huh.. (housing for exhaust wheel?? Same sized connections though right, but it might not fit under the standard heat shield?
Sry, i didnt think was worth searching for, assumed both were the same.. Ill do one see if it helps
Hmm, i got 11 pages of topics without mention of "NEO r34 TURBO" in The majority, weird search function on this site >.<
All i found was "If he puts more boost into it (above another 1-2psi) it will fail under extended load" (quoted from you, talking about a 32 NEO) Which sounded odd, because mose people say that the 33 turboes are good for 14 psi on a rb20 which is a increase of 5 over standard. Granted that the r25 will put more strain on the turbo than the rb20, id think what this seems to suggest is that a standard series 2 turbo would be more reliable? Or am i way off? thx
Edited by r32 gts-turbo
Im getting the 34 turbo installed this week and came across my old topic, re-read it and got a question. A larger rear housing will mean it spools later ay.. So i will be expecting even more lag than a 33 turbo humm?!?.. Is it significantly larger or only a little, if its going to be to laggy ill sell it and buy a 33 series 2 turbo instead, any one?
Hey,
I have a RB20DET and im running a R34 Turbo. Im running 10psi on it at the moment but will be raising the boost soon. Full boost cuts in on mine around 3000-3500revs. When I had my Turbotach Maunual boost controller on I was running 13psi boost and the full boost was coming in at around 3000revs. I took the boost controller off casue i damaged the coils and had to fix them, will be putting it back on soon though, lol.
Hey,
Obviously loaded up in fourth..
You'll find in second gear pulling out of a corner it will pull well (snap in if you like) from 4k somewhere verses the stock rb20det turbo from 3-3.5k ish depending on boost run. The more boost the later they feel as if they snap in hard.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
