Well yep, Kev gave me some pointers and I had a fantastic day.
Great practise for Dutton Rally and I slowly improved throughout the course of the day!!
Thanks for your help Kev.
That was sooo much fun, more than expected!
  • Replies 167
Top day!!
Had a ball, car is still alive, except for the rear brakes... yowzers
No wonder I was getting taily under braking, it's metal on metal. Whoops!
Congrats to all who ran PB's, and very, very impressive Chris, mucho respecto :(
Ok, so Scothfinger has risen the bar....i always thought a 1:21 is about it for a neatly modded but std turb GTR...now just how fast can the cheater go on ceramics?
He, he, he, thanks guys - I just keep taking it out and driving the wheels off it. Hopefully that continues to be the rubber wheels and not the ceramic ones!
Didn't feel I put together a 100% super lap at any point in the day. So a 1.20 is achievable if I can actually get some sleep before an event. But I think that might be about all the car can give.
Well done mate - [darth vader voice] Impressive, most impressive...[/darth vader voice]
Regards
Andrew ;)
Actually, im so desperate to drive i will be more then happy to donate my one day old RE55s on 17" wheels for the day, if i get to do some sessions in the car ;) Actually any part needed off my car im willign to throw on their car for the day :(
You guys have no idea how hard it is watching you folk have fun out there:(
Actually are they still up for sale? What size is it
A guy is meant to be transferring money into my account, so if the money hasnt been transferred by Friday...then?!?!?!
They are 235/45/17s.
And its $200 for entry? Well that changes things a little as i may just go on a Wednesday when i get my car back...more laps that way.
Well that was fun... perfect weather for my first track day! big thanks to all the guys who put the day on and everyone who helped out being flaggies etc... also thanks to the WRX club guys (murph & Jason) who were my instructors on the day... they let me fly solo in the last session and I grew some balls and recorded my PB for the day 1.32 which isn't toooo bad I didn't think? but mostly just glad I brought home the car in one piece, the brakes, oil temps and tires were great all day (I mustn't be driving hard enough hehe)
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
