Have had huge issues with my RB20det lately, probs are, ignition cutting out at various points in the rev range (not a miss fire like a plug or coilpack would do, but rather a total ignition cut of all 6 cylns) Some times the problem is only while drifting through corners and not in a straight line.. but a couple of times it has happened while on fullboost in 3-4th gear in a straight line and the ignition will cut out, come back, cut out quite repetively.
Now while this is happening, the Tacho also dies... so to me it indicates a loose wire, or a problem somewhere in the wiring of the ignition system. This resulted in me pulling my loom out.. have a look at it and tell me if all the electrical taping in black is factory or not? I know the red tape looks to be non factory...
https://www.sau.com.au/forums/topic/127226-rb20det-loom-help/
Nissan does some funny stuff with its wiring, and I believe it is hand wrapped. Some of the black tape looks like a home job, but it's actually factory. Mine was the same. Red is probably extras somebody else has added on.
It could be a CAS problem? A few have had that problem on rb20det's. I think the ECU determines the RPM / Tacho signal from the CAS as well.
i had a issue like this, it would drive fine, then it would start cutting out. it did not matter if you were in a high or low gear, some times i could rev it to 7k and it would be fine, then other times it would just cust out.
i replaced the o2 sensor and it has been fine ever since.
To test if its the o2 sensor.. remove the o2 sensor plug. Car will work fine without it. Just won't run in closed loop mode, and you'll use more petrol.
Its something like the o2 sensor immitantly sends faulty signals the ecu has problems. But if you remove it totally you can isolate the problem a bit more closely.
I'm not sure how you test the CAS, you'd need to monitor the voltage signals, or use the consult connector to see what's going on.
Also when it does fail, stop the car, and put the ecu in fault mode, and it should flash the sequence for the last thing that failed.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
