Hey all
I have some of the best car audio up for grabs!!
** JVC KD-AV7008 **
Detatchable Monitor
Fully Motorized 7" In-Dash Monitor
Touch-Panel Operation
7" Widescreen Monitor TFT Active Matrix LCD
5.1ch Dolby Digital / DTS Decoder Built In
CD-R / CD-RW / MP3 / DVD / DVD-R/ VCD Playback
DSP / EQ ( 5 Band )
The Best In Car Entertainment unit on the market !!!
Still Have The Box And All Manuals for it.
RRP $3,200,00
** Clarion SCM300 **
3 Way Component Splits
80 WRMS
Best on market !
RRP $699.00
** DLS Basic Component 6" Speakers **
DLS 6 " Speakers
50 WRMS
Hand Made
RRP $150.00
** Kicker Competition Subs In Custom Box **
Two 12" Kicker Comp Subs In Custom Made Box
SUBS " 600 WRMS Each And Have Dual Voice Colis"
BOX " Custom Made To The Correct Volume Of Litres For These Subs "
SUBS RRP $550.00 Each
BOX $650.00
** Response Amplifier **
( Was Not The Amplifier Being Used On Subs Above, Mate wants that Amp ! )
This Amplifier Still Does The job Very Well !
50 WRMS X 4 Channels @ 4 Ohm
Hi - Lo Pass Filter
RRP $250.00
Over $6000.00 In High End Audio !! NOW ASKING $1600.00
Located In Adelaide
PM Me Or Give Me A Call On 0433 549 430
Edited by stylz7
https://www.sau.com.au/forums/topic/127482-top-end-car-audio-for-sale-for-1600/
Forgot to mention that most of the audio is less then 4 months old !!! Still have boxes and manuals for deck, amp , 3 way splits.
Will not find better for this price !!!
Cheers
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
