hey Guys,
now that my inj duty cycle is strapped i need to put the bigger injectors in.
i have them here, SARD 700CC (light Blue tops) but don't know where to get the Injector Latency figure for them so i can work out the adjustment factor.
444/700 = 0.634 so 63.4
0.772 - (new Latency unknown) = Correction
any one got a figure or a link?
surely someone is running SARD 700cc injectors with a Power FC, i just need to know what perameters to put into the FC so i can run them?
i have a wide band O2 sensor in car to get the A/F's right, but could really use a link or some information on changing ignition & fuel maps.
no Dyno in Papua New Guinea & no one with aftermarket ECU tuning experience....................just me!
would really apreciate any help :angry:
https://www.sau.com.au/forums/topic/127769-sard-700cc-injector-settings/
whenever i need lag time settings i just google them :)
hey Beer Baron, i'm all googled out :) , but i have been searching using SARD & LATENCY in every which way i can think of. are you saying try SARD INJ LAG Times?
i'll try that i guess :O
hey Beer Barron, you da man, "LAG" is what i should have been using. easy when you know how eh?
put the injectors in last night, running good even with std maps.
new injectors reading 68% at 1.2 bar under load where the stockers maxed out 100% at 5,500 in 2nd at same boost.
now all i need is schooling on how to change Ignition & Fuel Maps to smooth things out. i have a wide band O2 mounted full time, but want to knock the timing back somewhat to keep knock down as i'm forced to run on 91
know of any Video's explaining the proceedure & links? i did try Google, but failed me this time!
haha, glad i could help mate! I knew they were out there.
tuning is a whole other ball game though. basically you will need to spend a lot of time around the area that it's building boost really fast, and around peak torque. This area will have a propensity to be very sensitive to ignition advance. too much and it will ping/knock, not enough and it will be a bit sluggish and not build boost as fast as you'd like. this area (transition to boost) is crucial to getting a nice drivable car. basically you want to be getting the AFR right, then work on the timing. raise it until it knocks, then back off a few degrees at those load points that knocking occurs at.
and ABOVE ALL: BE CONSERVATIVE!
    • Out of curiosity, how do you cover up the inspection hole? Surely it doesn't sit open like that, right? With grime and dirt coming in and oil going out?
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
