hi everyone i just recieved pictures of the r34 im importing
its a 4 door gtt manual turbo but in the picture it looks like i have an auto steering wheel.. can anyone confirm it is true or is this for stereo control? also in the picture it looks like there is a fold out tv or cup holder or something can anyone confirm this? its just above the tape deck (sorry pics arent that clear)
ive fax the supplier my questions but i thought id ask here as well
Edited by sskylinee
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/
Either manual conversion or they whacked on a auto steering wheel (maybe the airbag blew and they had to replace the steering wheel)
The buttons you see are the tiptronic buttons I believe.
What does the dash look like? does it show the gears in the middle? if so the car was probably a manual conversion.
Above the tape deck, maybe a CD player? pretty sure its not a TV
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2361914
thanks 4 the replies guys..
i dont actually have any other pics that could help
i havent got the vin number yet but ill have to ask the supplier 4 it.. the buyer in japan is always at the auctions and takes a while to reply
the thing above the tape deck doesnt look like a cd player at all.. fingers crossed its a tv but knowing my luck its probably not :D
i have noticed that normally the tape deck is under the climate control and theres a spare din underneath..
but mine isnt..
ive attached another pic
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2363511
so manual 4 doors are rare? so my concern now is whether i got an r34 manual gearbox or could it be r32 or r33?? anyway of checking? do they even fit?
r33 gb and r34 are different right? ratio etc?
thought id add a pic of the whole car (show off) :)
shes stock to the bone so i hope i wont have to many problems with compliancing
thanks again 4 the help guys
Edited by sskylinee
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364073
Main difference is r34's are push type clutch and 33's series one and before a pull type (or vice versa) I personally wouldn't be too worried if it's been done well.
Do you mind telling us what you paid for it?
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364122
if the conversion was done in japan, then you can rest assure it was most likely done properly, no need to stress too much. The only thing of concern is when you import a car like this that has been converted, the auction papers or your broker should have stated this fact.
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364281
how long is a while?
it took almost 6 months of looking before I got my manual GT-V sedan.
if you had a full pic of the dash we would be able to see which dash cluster you have because if it was originally a Tiptronic and they've left the tiptronic wheel in place maybe they've left the auto dash cluster in place as well.
if you have a copy of the auction report the VIN will be on it.
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2364546
  • 1 month later...
the thing above the tape deck doesnt look like a cd player at all.. fingers crossed its a tv but knowing my luck its probably not :(
but mine isnt..
Hi,
That is a tv that is connected to the navigation system located at your boot.
I slo have this in my R33 Series 2.
Im guessing its a factory option.
I was wondering if anyone has been able to either use the factory navigation system in AU?
Also I wanted to know if the tv can be hooked up to a dvd player?
https://www.sau.com.au/forums/topic/127792-r34-tv-monitor/#findComment-2477812
  • 1 year later...
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
