Well the fuel obviously.
could have been the tanker left the servo 5 mins before you and stirred a bit of crap up.
Just get another batch of fuel in a few days and take it easy
Either that or your fuel pump has just about seen its last day :D
https://www.sau.com.au/forums/topic/127883-different-fuel/#findComment-2363594
hey guys,
i just got home now and i poured moble 8000 cause i wouldnt get to a BP in time, the car coffed a little bit and i could hear detonation slightly under load, anyone know why this could be ?
THANKS
as far as i know mobil 8000 is better octane then bp ultimate? so why would it detonate? or is that mobil synergy? 99octane?
https://www.sau.com.au/forums/topic/127883-different-fuel/#findComment-2363656
hi guys,
does mobil 8000 contain ethenol? if so i would be banking on that if you're running aftermarket management.
glenn
https://www.sau.com.au/forums/topic/127883-different-fuel/#findComment-2364751
Either that or your fuel pump has just about seen its last day :teehee:
yah, agreed with ash.
https://www.sau.com.au/forums/topic/127883-different-fuel/#findComment-2365188
Take it easy if it is starting to ping. Don't rev the car or hit boost. You'll end up leaning the girl out and have a rebuild on your hands.
I put bad fuel into my car and she has been off the road for 2+ months now cause I didn't know any better.
:D
Use the correct fuel, and if you can't get there, just put enough in to get you to the right fuel.
https://www.sau.com.au/forums/topic/127883-different-fuel/#findComment-2366454
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
