hi guys just got home, picked up the cat and pipe from the GPO and the guy was like thank god its taking up a whole shelf lol. then he picked it up, aimed it and yelled BAZOOKA!
cheery faces all round thanks heaps it looks absolutely awesome a fair bit of work by the looks of things. hope it fits easy
thanks again
  • Replies 91
Posted Images
got mine yesterday...
didn't come by registered though just normal post.. not that i care because it arrived :D
having it installed friday hopefully...
will let eveyone know a comparison to how it was with the 3" bellmouth previously
got mine on last night. lined up perfect thanks again mic. got a nice whistle note to the exhaust now and got an extra 1.1 psi boost increase when running 9 psi. used to peak at 8.8 now at 9.9 psi so be carefull if your running higher boost :D
got mine fitted today, sounds a lil louder than usual, thou i dont have a cat back yet...
The dude charged me 190 bucks, i think i was ripped off badly, oh well its on now, he had to add like another inch of pipe cause it wasnt fully connected up, so i donno how that works out... Neways still very happy with it and it looks great!
maybe coz you got a 4 door car, so the lenght of the exhaust should be longer?? to connect to the cat??
Hmm 190 seems ok.. If the bolts snapped off or something then they charge more. its basically all labour. Took me 3 hours or so.. Or i think it was 4..
But still need to take it out again and heat wrap it..
What do u guys use to heat wrap it?
I was just about to bring this up - have people done it or not?
went down to autobarn and they sell some - looked a little dodgy though and $20 for like ~5m. Is it really needed as Ill Ive heatwraped up id the larger of the spilt pipe all the way down to where the smaller pipe joins the bigger one.
So should I spend another 20 and get it all wrapped up?
yeh i think it is cause i got a 4 door, the length would be a tad longer... but yeh i suppose i have no complaints over the installation, better payin a lil more for it to be working fine than paying less for it to stuff up
Well depends if you need to heat wrap it..
Mine is touching the aircon pipe.. The aircon pipe contains gases. SO think about. The pipe touch the aircon pipe in summer with high temps for long periods of time. Sooner or later its just gonna melt that pipe or make a hole. I will leave the rest to your imagination.
But if your wastegate pipe (the smaller pipe) doesnt touch the aircon pipe then it should be fine i guess..
Should be about 50 bucks for a decent quailty one tho.. Any exhaust shops should have them.
Im gonna heat wrap mine up b4 summer really hits. So most likley mid sept. Or i might have to relocate that air-con pipe.
Keep you posted i guess when i get mine done.
Edited by siddr20
Got mine fitted today, car is alot more responsive to say and the topend has picked up quite abit too.
Just wondering though: did anybody else have their wastegate split pipe VERY close to the gearbox? Mine is actually TOUCHING at the moment but the dump flange lines up with the turbine perfectly. Theres no rattles and bangs when driving at all, but I'm still abit paranoid - can anybody confirm this is ok? Michael?
Thanks,
Andy
got mine fitted yesterday
previously i had the 3" bellmouth and ran 14psi to make 155rwkw
with the 3" split, i ran 13psi to make 170rwkw :rolleyes:
that's 15rwkw at 1psi less! dyno graphs to prove if anyone needs...
oh, and the split pipe runs on the opposite side to the gearbox on the rb20.. mine almost touches some aircon lines but they are insulated so its all ok..
OnGsTa,
Check the pipe to see if it has any indentations at the point that its touching. it will most likely not be a problem because the R34 dump & front pipe is bolted not only at the turbo flange but also has a bracket that that gets bolted to the car just before the cat, so there will be no movement/friction against the box.
WazR32GTSt,
Thats a great difference! Thank you for sharing that information :rolleyes:
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
