Here is the fast for chassis: DR30 034944
I couldnt get chassis: DR30 021333 to work for some reason.
Do you have the model code for this one??
thanks mate. So build date is 09/1983?
na not for the 2nd one. bit of a weird car, had a l24e in it with mr30 plates. all the mounts etc look factory 2. cnt see any signs of cut and weld job around the chassis number either. off 2 sims metal soon anyway lol...
Edited by OUTATIME
Heya, could I please have mine done, am trying to work out what diff is in it exacalty because noone seems to know, it has it's own stand alone ecu for the diff and has 2 oil pumps under the drivers side rear, and there is a 3rd one which appears to be attached to the diff, also has a oil top up which is located in the boot. The only thing we can read on the diff is G3HJ08, the rest of it is unreadable.
- ECR33008466
- GGKBRVFR33
Anyways thanks ;)
you almost certainly have the active rear diff, there are pumps that push torque to the side with more grip based on the wheel speeds instead of just a mechanical setup. It was on all 33 Vspec GTRs, and a very few GTSts have the option as well.
they are a good diff as long as everything is working OK, but they can be hard to troubleshoot and repair because very few people know about them, and there are few spares around
Unfortunately I can't get your vin# in my copy of fast to confirm.
Best way to check, you should have an ALSD light on your dash that you would see when you first start the car
Yeah we have the ALSD light and a slip light as well on the dash. Atm we are having issues with it staying on alot of the time. But if we get it out our drive way then turn it off and then basicly move the car as soon as we start it won't stay on. Problem is the ALSD light often comes on when any sensor in the car plays up.
Thank you for your reply, it has helped a little in trying to explain what diff we have to nissan if it is in fact the diff sensor that is running a muck lol.
could someone look into a 6u900bcnr33022973 please as supposed to be limited edition. Thanks!
Appears to be a legit limited edition r33 gtr vspec. The paint code is BT2 - Champion Blue (exclusive to R33 GTR LM)
here you go mate
Edited by babyskyline
can some please do 6u900BCNR33041211, including engine number and options
thanks :rofl:
Nissan Fast cant tell you an engine number.
Here is your fast mate.
You might want to pm Chook to get your options translated as i cant.
Guys I am wondering if someone who can read Japanese can help me out here. I need to get a new door actuator for our Skyline I have fasted the VIN and worked out the part, I have even taken the part out of the car onyl to find that there are not part #'s on it. so looking at the FAST software it give me two parts #'s for the same part. Only thing that differs is the desciption and the dates, but my vehicle was made durint hte over lap of the dates so can someone tell me what is the different between the two parts and what is the correct part for the actuator ie the electronic part in the door.
thanks for any help apologies if this is in the wrong section
Edited by bigafoot
OK, 80552-AA300 is for cars with remote control entry. Other is not.
hope this helps.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
