Hey babyskyline,
Thanks mate, I promise this is the last one I ask you for :)
Its a White 1996 R33 GTR, Non V-Spec.
VIN: 6U900BCNR33023950
Engine No: RB26060767A
Hopefully this all matches up!
Cheers mate.
Edited by GTR-PWR
Hi, can someone please fast the following BCNR33040360. and also can datsuns be done aswell? if possible HGC110017540
cheers,
Here is your fast for the r33 gtr. Couldnt get the HGC110017540 to work on my version.
Hey babyskyline,
Cheers mate.
Yeh mate it comes up as a white 1996 R33 gtr.
He is advertising it as a 1996 GTR VSpec, does the FAST result say its an 1995 October build? :D
Also, does KLO, mean grey colour?
KLO is spark silver for the r33 gtr.
If you go here all the paint codes are listed. http://www.skylinesaustralia.com/forums/Ni...es-t138419.html
hey guys,
This is the VIN number i got off the rego sticker for my car:
VIN: 6T91MPV97P2WYW001
SN: 0407508
Is that sufficient information for you guys to do a check or do i need the number from the plate inside the car?
cheers :)
hey guys,
SN: 0407508
cheers :blink:
nah mate, you need the one on the firewall of the engine bay, it should read something like 6U900xxxxxxxxxx
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
