Usually on the 4th line of boxes where it has GTR if it were a vspec it would have GTR/V or GTR-V in there so yours is unfortunatly not a vspec
Ah, thanks for the answers.
This chassis number is one off carsales that I'm quite keen on (the ad said V-Spec, I thought I'd check with FAST to be sure).
mmm I have one. Ran it through FAST when i bought it but the program has since been evicted by parental units, and im interested in dissecting the model code to find out if the car is a V spec or not. there are a few things that suggest that it is, but it wasnt old as one, ec.
So for the sake of curiosity, if we could -
BCNR33 041082.
Please =D
BCNR33 041082.
Please =D
i'd say its not. in the attached screen shot you can see the 6th letter along in the model code (with the small red line i drew under it) is a Q. in the model code breakdown window the the Q with the red line i drew before it means just a normal GTR. further down you will see the blue line i drew with the letter W next to it that means V-Spec.
Thank you =D
I've posted in one other FAST thread, but this one seems more popular, it's my baby of 2 years,so I'll ask here as well, i'd love a screen shot (here or email isaac AT islade DOT com)
6U9000ECR33009874
Thanks :blink:
here ya go
I need to confirm if BNR34-401788 is an N1: can you help please.
Also have the following
GGJPRWYR34ZDA--1--
Thanks muchly
It's shown in FAST as a 'GTR/V2' which would be a 'V-Spec 2' if there was such a thing for the R34. So I can only assume that translates to an N1?
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
