R33 GTS/S
Non Turbo RB25
Manual
Couldn't get a colour code i think its because its a non turbo... same as the guy a couple of posts above the vin no. won't recognise had to use model number.
Thankyou, You've put my mind at rest about it being a auto converted to manual, glad it's factory manual at least haha.
March 1997
R33 GTST Type M
Manual
Color field is empty as i believe there is something wrong with your vin.
Cheers lanky, finally got their in the end :D
wierd tho, the guy i bought it off was 100% sure it was a 1996.. its even rego'd as a 1996.
ahwell..
(also the car is white, but i have a suspicion its been resprayed from black)
thanks again lanky + the othes who helped
i may have missed it, but is this FAST check limited to skylines only or can s13's be fasted?
Yea I'd say so ....mine is givn me lists of parts 4 s13z
whats ya vin someone will fast it
not quite a VIN request guys, but i'm in need of FAST so thought i'd post it here.
i have what i believe to be an r32 gts-t wastegate actuator.
it has "ASN 79 - 24 *something* 525" on it.
can anyone confirm if this is the correct part number? or what the number for an r32 gts-t actuator is?
thanks a lot :wub:
Ric
thanks a lot :D
Ric
nissan part no.z are usually something like 14483-04U05, I think the 32s had at least 3 different actuators (can't read Jap,sorry)
if you are after the program 4 yourself I'd suggest you google :- 70F6451B09CD69E8758A32264323C8E85CD74910
hope this helps some
Edited by BundyBear
Sigh...... here's a wobbly for ya's to try ..... i just installed FAST , and it correctly pulls up all the info on the VIN's i randomly selected from this thread to try, however, ofcourse, it says mine cannot be found.
ECR33 012643
Its a S1 r33 4dr auto.
Oh and just for a total smack in the face .......... 012642 and 012644 WORK !!!!!!!!!!!!! AARRRGgggggg
Gary
Edited by Fastrotor
I only get yours to work when entering the model number then vin no. but its a general info like ones mentioned above no colour code info.
Just to double check it gave me right info October 1993 built?
I always though it was 9/93 so Oct sounds correct. How do you mean entering model THEN Vin no ? Im new to Fast sorry.
I have to enter ECR33 , then tab to next box and enter the number XXXXXX to get it to work, do you mean this or something else ?
Gary
This is the only date i have on the car, the importers plate.
Edited by Fastrotor
6U900BCNR33003083
cheers, thanks
R33 02/95
Color # kn6 (Plumb)
Interior :k = Grey
Model :2k
GTR
RB26DETT
5sp Manual
HikeAss
4WD
Model No.GGJPRQFR33ZDA-J---
EDIT:: FYI the 6U900 just means its an import. its not part of the VIN as far as Nissan is concerned, just the RTA, cops n the like
:: ghostflameR33
I could be wrong here ubt I don't thing FAST includes any Engine No data as it's primarily 4 Spare parts
google is GOD
Cheers all
Edited by BundyBear
R33 02/95
Color # kn6 (Plumb)
Interior :k = Grey
Model :2k
GTR
RB26DETT
5sp Manual
HikeAss
4WD
Cheers all
thanks mate, but are you sure on the colour? Mine is Midnight Purple....
yea preety sure, mine is the same color KH2 ( looks gunmetal grey with red and blue 'perl'), the color code is actually on the compliance plate(firewall one, not import plate)), just above the engine type, RB26DETT . See port #1713, his paint code is KH2. This will confirm FAST info, and if the cars has changed color. KH2 is also refered to as gunmetal grey sometimes
PS midnight purple is a rare colour, price me thinks, codes are
LP2 (R33)Midnight Purple (no Chromalusion, has 2 pearl tinters Violet & Red)
LV4 (R34)Midnight Purple II (Chromalusion Tinter KK760 Absolute Purplene & Vilot Pearl)
LXO (R34)Midnight Purple III (Chromalusion Tinter KK700 True Blazberry Prizm & 2 pearls red & Violet)
see Here for ALL the Paint codes
    • Hey keep the ideas coming, I'm always keen on projects! But, problem fixed!  I got a cheapie ozito scope from Bunnings and had a good look in and around the bearing and sensor hole. I couldn't see a smoking gun but the bearing looked a bit strange, especially when comparing with a new one. I thought the cover had come off the bearing magnets.  Sorry for pics of a screen, I didn't have an SD card.     Good thing I had the old one to inspect. So, given I'm like a pit crew with wheel bearings and luckily I had a spare bearing because I f**ked up my parts order, I decided to just smash it out. Got the old one out in about an hour. So much easier when the parts haven't had a chance to rust together yet. 😂 And, well, found the problem.    In the second pic at about the 8 o'clock position, you'll see what I think is the tip of the old sensor.  The new sensor has definitely been rubbing but it's all intact, just a little shiny so I'm hoping it's fine.  The car brakes perfectly now and no errors.  I think the job took about 2.5h in the end. 👍🏻 I really appreciate the help in here as usual. Thanks guys.
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
