The numbers I got given for the car I want to buy are:
VIN: 6T91MPAAATXBVW001
CHASSIS: BCNR33-002306
I may have to contact the seller to get him to resend
I tried again but it didn't work. Sometimes this can happen and it can work on other people's FAST programs. Can anyone else try?
Thanks.
Anyone know what the last box is on the left in the second last row? The one that states "GT-R.17
Gonna take a guess here...
All the R32 GTR screenshots I have saved are all non-vspec models except for yours. All the regular GTRs just say "GT-R" in that box. Yours is a vspec and says "GT-R.17". Maybe its referring to the standard 17" wheels as a way of identifying between a regular GTR and a vspec GTR.
The "8" (third last digit) in the model number signifies the GTR V spec II. Is there a possibility that it could be the build number off the production line? there was only 1303 produced.
Hmm I don't think it would be the build number. If I do a generic "R32" search in FAST, I'm able to click that button and it shows me all the models of the R32:
The ones we are concerned about are GT-R and GT-R.17, which both of them are there and there are no others saying something like GT-R.1000, for example.
So I then looked for a vspec vin number on google, searched it and it says GT-R.17.
Then I searched another vspec vin number to make sure and it also says GT-R.17.
So basically, I'm pretty sure its just a way to distinguish between a regular GTR and a GTR vspec by using the .17 as a reference to the standard wheels, as I said before.
Hope this helps :P
Hope this helps ;)
Certainly does Dark26, thanks for all the effort, appreciate it.
BCNR33-042666
please
BNR32012779 the car is pretty stock with all the nismo gear on it. can this programme tell if its an original nismo or a standard? ta
Apparently, Nismo GTR VINs start with BNR32-100XXX, and regular GTRs start with BNR32-000XXX, and yours starts with a 0.
Also, I found a Nismo GTR on SAU and the VIN started with a 1. Also, at the end of the model code, there should be a 'RA' which stands for 'Nismo Group A Limited Edition' but yours says LTZG.
Ah k shame, i really had hopes it was a nismo version lol. had the bonnet lip, the dash, stickers etc. And the car was pretty much stock. All it has is a cat back exhaust, pods and rwd switch lol. ah well thanks alot mate. shhh "ill just pretend its a nismo anyway" shh hahha
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
