hope someone can help just purchased an r33 and it has two plates, blue and green, and a silver plate in the middle with the VIN
the numbers i have from the jap blue plate is ECR33-016380
hope thats enough info?
Correct information (as per my signature), but the VIN seems to be invalid. It would appear to be a series 1 (early ) number, but perhaps there is a digit incorrect there?
I changed the last digit (0) to an "8" incase that's the mixup, and it is a valid number.
Is that what the ".17" means on the end? Someone else asked this question earlier and I didn't have a good answer other than "it's not a regular GTR." =-o
The .17 means GT-R with 17 inch wheels aka Vspec.
The model number ends in ZN which is N1.
Stupidly rare car, has been auctioned in Japan twice in the last 6 months.
hi, incorrect my car is 2door, is automatic, is skyline r33, it has hicas, the vin says ECR33-016380 - checked a few times.
then the green vin starts with 6E91xxxxxxxx05053
the plate also has written under the ECR33
GGKBRNTNR33EDAA
KH2 K
RB25DE
AGAIN I AM CONFUSED.
Ah yes, bigger wheels for sure... I get that now. N1 is the Nismo enhanced version, and we can deduce that it's a VSpecII because they were introduced in 1994?
Wiki:
To celebrate the success of the GT-R in both Group N and Group A racing, Nissan introduced the Skyline GT-R V-Spec ("Victory SPECification") car on February 3, 1993. The V-Spec added Brembo brakes and a retuned ATTESA E-TS system to the Nismo and N1 packages, as well as 17" BBS wheels with 225/45/17 tires. The V-Spec has a list price of ¥5,260,000.
Finally on February 14, 1994 the Skyline GT-R V-Spec II was released, with the only change being wider 245/45/17 tires. In addition, both the V-Spec and V-Spec II had a curb weight of 1,480 kg (3,256 lbs), weighing 50 kg (110 lbs) more than the standard GT-R.[11] Total production of the V-Spec I and II was 1,453 and 1,303 units respectively.
Oh wow... that *is* rare! haha!
GGKBRNTNR33EDAA
KH2 K
RB25DE
Well, I don't want to tell you that it's fake VIN or a grey import or anything like that, but i've not come across any VIN that hasn't populated in the software.
The model should work but even that does not. I know there are 100 R32's that were locally delivered, but to my knowledge no R33's were ever locally delivered... so I would expect that as a Japanese R33, it should be in this Japanese database.
Could you take a picture of the plate?
hi,
I have registration papers with that 6E91 vin number, I have now taken photos of the vin from japan, and it definitely says ECR33, could it be the GTS4 it is the RB25DE engine and it is coupe and auto, it may be the GTS25, my main point is, does the vin plate says RB25DET if its turbo or does it just say RB25DE?
I am confused, I have all the paperwork, and the original owners 'National Warranty Company' booklet for victorians, as this car was bought in VIC and transferred through regency to SA, as i have the regency papers.
I just want to know if its a factory GTST or a GTS or GTS25 or what? different people are telling me, different things. if someone is able to email me privately i could send them the photos of the VIN and COMPLIANCE plates?
thanks
G'day mate could you check this vin it's meant to be a 1990 r32 gtr nismo gunmetal kh2 paint code
Vin: BNR32-100032
Model: KBNR32RXFSL RA
also if it's possible to find out If it had a/c and radio as I've been told that it was an option on the nismo
hi,
thanks
If it was originally a GTS4 (i.e it is 4wd) it would be ENR33. I tried them all this morning, and no combination would work.
F = CA18
H = RB20
E = RB25
B = RB26
C = Super HICAS
N = Atessa
R = Chassis
CHASSIS CODES
-ER -- GTS25
-HR -- GTS
-ECR -- GTS25t
-ENR -- GTS-4
-BCNR -- GTR
Yes, if it says ECR, it is a turbo chassis/engine. The brakes are different, the number of wheel studs are different... i'm sure there are many other differences. If you had a motor swap, and you have a DE (Dual overhead, EFI) then either the plate is wrong, or the motor was swapped out.
So... if your chassis was a turbo model you should have 5-stud wheels, a stronger gearbox (not sure how to tell, but it could be a manual-only thing), obviously you'd have no boost gauge in the dash. The side-mount intercooler would have plumbed through the engine bay via two holes infront of the air filter box. That should be very obvious.
Check those things? If the chassis has all non-turbo parts, I would *guess* there is something wrong with that plate. Strangely though, that plate doesn't belong to another chassis... it just doesn't exist. =-o
Let us know.
-Steve
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
